157
Everything posted by lmdew
'02 Outback heads
lmdew replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
www.car-part.com is worth a shot for heads. -
'02 Outback heads
Drive it. -
'02 Outback heads
What's the mileage? Piston slap is not a huge problem. Does it go away when up to temp? I'm sure GD has more info for you. -
Update 12/24/2021: Subaru extended warranties on 2012-2018 models to cover this part at least until 10-31-22. • 2022 Update. Key ... This "fix" bypasses the park-range switch that often fails in 2015-2018 or 19 Outbacks. My wife's Outback has not had a key stuck since I put in the jumper wire and no dash lights have come on (the key was getting stuck regularly). The only risk may be that you can now remove the key with the car in drive, neutral, etc. If you can't live with that risk, then you better replace the switch per Subaru service bulletin # 16-112-18R (https://static.nhtsa.gov/odi/tsbs/201.... This same method may be able to be applied to other Subaru models. Many modern Subarus use a similar wiring harness and wiring color scheme within the shifter console. If you want to try it on your own car, do so at your own risk. Also, remember to make a video so we can all benefit from your effort. From Youtube: Subaru Outback Stuck Key in Ignition / Park Range Switch Bypass Fix / Repair / How-to - YouTube
Cleaned a the connectors. I tried slaving in the old Trans switch, no change. I pulled the shifter apart and could see the switch. The shift lever was moving too far FWD and the SW opened again. Pull back on the shifter and it works as it should. Engine is running well. I just need to find a CAT to stop the exhaust leak.
Never throw away/recycle Subaru Parts, you will miss them! New 98 has a hole in the CAT. I recycled 4 of them a year ago and now I need one! Anyone have one around? Second, the Key is stuck in the ignition. It will not come out. With the old trans it was fine. I think that switch is in the shifter and not part of the transmission so I don't know what would have caused it. Troubleshooting to do. The engine was dirty as can be. Headed to the car wash with degreaser. It's much cleaner now but developed a stumble. I put the proper NGK plug wires on it as it still had the DOHC 2.5 wires. I may just let it dry out while I'm off on Holiday for 2 weeks. Time to clean the garage!
