153
Everything posted by lmdew
I'd just get a set from a nice rust free area along with struts and bolt them in. Save the hassle. www.car-part.com I could pull a complete set shocks, hub, disk Caliper for about $150 each side and then it would be shipping from CO. www.nasioc.com is also a source of good used parts. Fellows sell their stock stuff all the time.
2.2 engine swap is the best way to go if you need a new engine. You can get one and install it yourself for close to or less than the costs of the HG and Valve work.
Did you get the knock sensor properly positioned? It has to be clocked so the plug end of the sensor is in the cutout and it sits flat on the engine. If you didn't do that you may have damaged the new knock sensor. Yes, mis fires can cause loss of power, as will the retarded timing due to sensed knocks.
You can take the old radiator to radiator shop and they can check the flow. Sounds like you have an air bubble in the coolant system. Search Burping. You can put the Stat in a pan of water and heat it up and make sure it's opening at the correct temp. It can be hard to move the air out of the coolant system if it's in there. Some, start the engine and fill as the engine is running. I usually jack the car as high as possible in the front, back fill the engine with coolant and then start the engine and fill the coolant slowly the rest of the way. With the heat on high, keep on filling the system as it heats up. Once the coolant starts to come up in the radiator, put the cap on and let it come to temp. Shut it down and let it cool. The system will draw coolant in from the overflow bottle. You may have bad radiator cap if it's not allowing the coolant to be sucked in.
Two different problems. The Flashing AT Temp light tells you there is a fault in the trans. Search Torque bind. The Knock Sensor fault will retard the timing which will degrade performance - power. Misfire on #2, start with the basics, New NGK Plugs, New Plug Wires, Subaru or NGK and Sea Foam in the gas tank. Map Sensor, Clean the connector first. Misfires are not a good thing for an engine and should be corrected to prevent additional wear and tear.
Sad to say, I have not gotten to the Pan, nor did I replace the valve stem seals. I know I could do both with the engine in the car but might just be easier to pull it. It will go to the sideline for a month or so, got 6 other ones that I'm working on and lots of travel for work. Thanks for the feedback! Larry
Gunk Engine Cleaner helped, as I ran the engine with it in the oil I could hear the change. The oil consumption is down but still high, a quart of more every tank, 300 miles. I can get the engine to smoke out the tail pipe if I rev the engine numerous times quickly Idle to 4000 RPM and back. Steady RPM it's no smoke. Review of items done and the engine: 154K 2.5 SHOC 2000 - Had bent intake valve, so I surfaced the head, glass plate and replaced and lapped all the valves. Engine runs great. - New Subaru PCV - All hosed clean and connected properly - Seafoam in the gas and Oil - MMO in the oil - Leak down check, see numbers above - Gunk Engine cleaner, seemed to help but did no solve the problem - No external leaks - Runs Great Pretty much down to stuck Oil control rings, engine pull. Thoughts?
Yes, they can be tough. Slip joint pliers behind the Tee Handle on the boot and the Lever it straight out. There is a special Spark Plug Wire Puller but this works most of the time. For the Mis-fire grab the CEL code first. Use only NGK copper core plugs, the cheap ones and NGK or Subaru Wires. Anything else and your asking for trouble.
I just changed one and it worked fine. I pin punched it and then tighten it until I felt resistance - tight, it was about 1 3/4 teeth. It was just a nice way to confirm the count. Count as you turn it back in and take it to tight and then back it up to the marks.
- 15 replies
2003 2.5 Impreza SOHC had been using approx. a 1qt every 200 miles. - New Subaru PCV help some but did not cure the usage - All Hoses hooked up correctly - Only 3% leak down - No External leaks - Seafoam no change - MMO no change - Last attempt ran the Gunk Engine cleaner at idle for about 30 minutes (way longer the specified on the instructions) as it worked I could hear the engine change. So far so good, 200 miles and no oil usage, no smoke. Only 154K on the motor with new HG due to the bent valves of the timing going for the PO. I usually would not use the Internal "Cleaners" but I was down to pulling the engine apart so nothing to loose.
