153
Everything posted by lmdew
97 legacy obw
lmdew replied to nshook's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Rebuild 1500 - 2500 Swap in a 95-98 2.2 used motor 400-500 You pick. I love the swaps. -
Could be, whoever did the work, did a crappy job (Brakes Plus) was mentioned by the PO. Why anyone would even go there is beyond me and to have engine work done at a brake shop just makes no sense. Just some of the things I notices when I removed the engine: - Missing Intake bolt - Wrong hardware on the engine lower mount studs - Lower Starter nut missing - Rear Power Steering mount bolt missing - Everything way over torqued I'd like to say you get what you pay for but they paid way to much for this "Crap".
If my memory is correct the N-SW drops the voltage the ECU is sending, 5vdc drops to 0 vdc when the switch is made. This tells the ECU when you are in gear and when you are Not in gear. The ECU needs to see this switching or it will throw the code. It expects to see the shift action. Just disconnecting it will not solve the problem. I learned this after a Auto to manual swap in a 96 Legacy and it kept doing the same thing you indicated.
Mostly, but the 96-99 DOHC 2.5 engines have internal head gasket leaks that blow all the coolant out. Easy to check, look in the overflow bottle, any oil gunk stuff indicates the HG are leaking. Ask if they were done. Most people never know they are overheating their engine until it stops working or the steam is coming out from under the hood. If it go to long, the bottom end is most likely junk and you either need to replace the engine or do a complete rebuild. 2.2 can be swapped in.
Drive Shaft Repair Option, just had a fellow here in Colorado Springs with vibration and here was his solution. It turns out that it was the 1st u-joint coming out of the transmission. It was super sloppy and quickly self destructing. When I took the driveshaft off I noticed that the front u-joint had been repaired before. I ended up taking the driveshaft to a place called driveline south of downtown. They machined all three yolks to allow removable c-clips (the OEM driveshafts from Subaru are "non-repairable") and I had them replace all three u-joints with greasable ones and balance it. No more clunk and its running fine. Thanks again for pointing me in the right direction.
Yes it will bolt up ans should work just fine as long as the front and rear diff's are the same gear ratio. Yes, the looks are pretty standard for a used trans What is wrong with your trans? The AWD not working is most likely the rear clutch pack or C-Duty not working. The bad part is unknown condition of the trans and no way to really figure it out unless you install it or rebuild it. $100 is not bad but a Trans change is a full day of work and not easy at that. Them suckers are heavy. Good used from a yard may be a better bet.
I picked up a 98 Legacy Outback 5sp with 229K on it. The PO had spent over $1400 on engine work. I didn't get all the details. Anyway, 12 months and 1 week later (week past the 12 month period) it just stopped on him. No more money going into the car so he sold it. When I opened it up the intake cam on the driver side had exploded. Nothing left of it. All of the other cams and cranks seem good. It was very low on oil so I'm think oil starved. Anyway, with all the cams closed the crank does turn over fine and it seems like there is good compression and its even on all 4 cylinders. What are the odds, the cam just froze up and took out the gear and if I swapped out the head it might be OK. Long shot I know but I thought I'd ask those with much more engine experience than I. Thanks Larry Just talked with the PO and he said the engine was rebuilt in 2010. No oil light on, He had heard some noise but it went away when hot. He was in the parking lot, started the car and it just stopped. Oil starved Cam, I'd think.
Well, you got most common items covered. Clock Spring? Any problems with blinkers, horn, airbag? Those are all part of the clock spring wiring.
- 8 replies
- Cruise control
- actuator
(and 1 more)
Tagged with:
That's a pretty good price. Take a look at the bottom of the engine along the block to head seam (HG) and see how bad they are leaking. Even if they are leaking as long as it was not run out or low on oil or coolant you could run it like that for a long time, just keep on adding fluids. If you do the HG yourself, figure about $500 for parts and machine work. Any idea if the timing belt and water pump were changed a second time. 105K, 210K would be the scheduled changes. If it's in otherwise good condition, tires, brakes, struts.... It's a deal.
www.car-part.com is a good place to start looking. Used, make sure the Head Gaskets were done or do them before installation. Several guys in CO rebuild the engine for 1500-1800 but you need to have a good core. No reason to switch to a 2.2, it's not like swapping the 96-99 DOHC 2.5 for a SOHC 2.2 from a 95-97
Well if it not broken don't fix it. only thing that can fail that's easier to get to with the manifold off is: - Knock Sensor - Coolant Temp Sensor You really don't need to remove much to change out the Intake gaskets as you an just lift the intake up a bit and slide the old gaskets out. As long as there is no stuck gasket you have to clean off you can slide the new gaskets right in and bolt it back up.
Have you tried going back to the stock Intake? Did this just start or has it always been this way?
