175
Everything posted by lmdew
A few years ago I had picked up a 2.2 from a fellow. I pressure washed it and then it sat for a month. I had the same issue, the crank was hitting something. I use the borescope at work and looked in the cylinders. Rust had built up on the wall stopping the piston. I soaked it in trans fluid for a few days and then slowly worked it back and forth until it rotated freely. Never had an issue with the engine after that. Good luck.
If you sleeping in the back Legacy Outback! You will like the extra room
- 21 replies
- Australia
- Backoacker
(and 2 more)
Tagged with:
97 legacy gt 2.5
lmdew replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Anything is possible with enough $$$$. Comes down to how much you want to send and the reliability of the engine once it's built. Read the Franken Motor thread. -
Call Mike at 970 217 7551 - for $1500 or so he will rebuild it. You can also Call Shawn at Retroroo 720-440-1662, also a rebuilder. Or CCR, sorry I don't have there phone, also in Denver.
- 3 replies
- Outback 2005
- Outback
(and 3 more)
Tagged with:
What CEL code are you getting? Cutting wires is never a good idea! Most engine sensors are very low voltage and any corrosion or poor connections can set a code. When the engine detects Knocks, it retards the timing to prevent knocks and thus the loss of performance. 5-30 oil is recommended for most Subaru's. Since this started after the oil change, you might want to start there. New Oil and a Subaru filter are way less than you've spent in parts and time.
Swap to Disk Brakes. I have everything you need $200 + shipping from CO 80919
- 17 replies
- rear
- suspension
(and 4 more)
Tagged with:
I would not trust the JB weld fix. The IAC or Throttle body are easy to come by. Heck for $20 shipped I'd send you both.
- 3 replies
- overheating
- waterpump
(and 1 more)
Tagged with:
I've gotten some off Ebay, it was a long time ago. I've also used the old plastic and mounted in a sealed low beam lights. You have to cut out some of the back plastic but they will go in.
