153
Everything posted by lmdew
That's all the damage? I'll give you a $1000 for it and drive it back to CO. Call a couple of yards and see what they will give you for the car. Add a couple of hundred to that price and that's what you should be able to get from a individual. Totally depends on the person's need for parts. Shame not to keep it on the road with the limited damage. Larry
Put a helicoil in the trans lower starter bolt hole and they will be good to go!
- 22 replies
- 2.5to2.2tran
- help with swap
(and 1 more)
Tagged with:
95 2.2 5sp in the near future I hope Glad you are all righ Larryy
Backed it into the garage today and got on the throttle pretty good. Yes it smokes. Replaced the PVC valve and I'm running some MMO with the oil to see if it frees up the rings. Might be a rebuild. Hard to believe it runs so well. It's like I'm driving the old Caravan with the 3.0 smoker in it again. Thanks Larry
154K on the motor. Previous owner had bent all 8 intake valves so I replace the valves and head gaskets. Runs great but using oil like mad. No external leaks, no smoke to speak of. Ran it 300 miles yesterday at 75 or so, down almost 3 quarts. PVC is valve is good Ran Seafoam in the oil for about 30 miles and then changed the oil before my 300 mile trip.
The nylon bushings on the rods that connect the wipers go out. Pull the wiper arms Pull the plastic cover that goes across the bottom of the windshield and under the hood You will see the linkage and rods. You have to buy the complete rod as I have not found replacement bushings. Dealer or Junk yard.
When I flush, I pull the radiator trans hose, drain and fill the trans and then start the car. The trans will pump out about 3/4 of a gallon, shut off the car and fill the trans again. Keep doing this until the fluid comes out clean. On the second or third start I hold the brake and shift through the gears a couple of times. Works great, pumps all the old stuff out first.
Sounds like the typical Starter contactor. Check the cables and grounds and make sure you have good voltage to starter. If you have a meter you can check the voltage under load at the Starter and at the starter motor. Sometimes a little tap on the starter may get you going but it's not a fix.
- 6 replies
- 1
- ignition click
- wont start
(and 1 more)
Tagged with:
