153
Everything posted by lmdew
My son is in Fort Collins and has been well trained in Subaru's. He's busy with work and college but I'm sure he'd take a look if it's not urgent. Oil leaks are pretty easy on the 95 2.2 Rear of the engine - Breather plate or Cam cover Side of the Engine - Valve Cover Gaskets Front of the Engine - Make sure it's not the power steering pump or oil pressure switch. If those are clean and it's coming out of the timing cover, cam or crank seals or the Oil Pump needs to be resealed.
Did a 97 Impreza OBS to forester Strut change today. The rear link mounts broke 4 of the 6 nuts loose inside the frame. I had one bolt on each side out and the other 4 loose. Removed the rear seat bottom and plastic door sill plates. Drilled up from the bottom in the good hole and then used a cardboard template to locate were to drill the 1 1/2" hole down from the top to access the other nuts. Worked well. The bolts were corroded above the nut, the nut and bolt part that was inside the nut was pretty good. A few breaker bars and some work allowed us to remove all six bolts and reuse them as we installed the new trailing arms. All of the holes were under the rear seat, so we just left them.
Oil pan screws
lmdew replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Take one to Ace Hardware you should be able to match the thread pitch. Or Hit your local yard. Easy to pull a few. -
Get the #'s off the two transmissions and look up the gear ratios. There is a 2 letter code on top of the rear diff that provides the gear ratio but you have to pull the diff to see it. Larry
If the fluids have mixed and they have been driving it that way you may have bottom end damage to the bearings without proper lubrication. If you put the money in to the HG and then a rod bearing goes you will not be happy. If they want to keep the car you might think of a total rebuild or used motor.
- 10 replies
Could be high resistance in the relay contacts. Again checking the voltage under load at the headlight is the best way to figure out what's going on.
- 8 replies
- lights
- headlights
(and 1 more)
Tagged with:
Check the connector on the lamp itself. Lot's of times the connectors are loose and there is high resistance. I've seen lots of them melted. Check out, www.brighterideas.com I bet you have a voltage drop in the system. LoadPro will find the fault.
- 8 replies
- lights
- headlights
(and 1 more)
Tagged with:
