Everything posted by Wagon Wagon
In need of a little advice/troubleshooting here... got a humming sound that starts at around 35mph and gets louder the faster I go. Sounds JUST like a wheel bearing going out. However... I can't pinpoint the sound to any specific corner of the car. The sound doesn't change when going around corners. Both front wheel bearings have been replaced in the last 2000 miles. The rears are original. I checked all four just to be thorough- no wobbling or excess play at any wheel. Scratching my head on this one... anyone have any advice on what I should check? Car is an 09 Impreza 2.5i, 95k miles, manual trans.
School me on Year Changes...
Wagon Wagon replied to Shortaay's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Most of the parts from the 86 will fit your 1990. To use the engine you'll have to use the intake manifold off your 1990 but the rest of the engine is basically the same. The body panels will fit your car, however the plastic trim on the fenders and doors of the 86 is stuck on with adhesive where yours pops on with little plastic clips. You'll have to either live with the mismatched trim, drill holes for yours, or remove the clips from your trim and stick it on with mounting tape. Corner lights and bumper have a slightly different appearance but will fit. Not sure about the power window switches as I've never had to swap one of those out. Also, that dual range 5-speed bolts right in, all you'll need to make it work other than the shifters are the center console trim pieces from the 86. EDIT- Forgot I also had to replace the oil pressure sending unit when I swapped a carb engine into my 1992 Loyale. -
There is water inside that car somewhere. As others said it could be clogged A/C drain and the A/C does run when the defroster is on. Or it could be a leak coming in somewhere. It really doesn't take much- my Impreza had a very small drip inside the trunk in heavy rain, the water ran into the back seat padding which sucked it up like a sponge and the car would fog up like you wouldn't believe. If you rule out the A/C drain issue you're going to just have to try and find the water. Check the lowest points of the cabin first- front and rear floorboards, under the trunk liner and inside the spare tire well. The best way is to just run your hands over it until you feel dampness. In the case of my water leak it was small enough where I couldn't even see the wet spots. Also if you have a sunroof, your sunroof drains could be clogged allowing water in through the headliner. Water leaks are a pain- 99% of the repair is just finding out where the water is coming from.
Value of a New Ea81 Engine
Wagon Wagon replied to Naked Buell's topic in Old Gen.: 80's GL/DL/XT/Loyales...
6000 miles ≠ new. -
Is it a constant click-click-click while moving or just one click when you turn the wheel? If it's the former an axle is likely the culprit. Sometimes they still can fail even with an intact boot, especially if a precious owner replaced a torn boot after a bunch of gunk had already gotten into the joint.
Says in his original post he wants to put a '92 Legacy 2.2 into a '98 Outback.
- 5 replies
- 5MT
- motor swap
(and 2 more)
Tagged with:
Re: the trade, honestly I'd just either sell it on Craigslist or donate it to charity (around here NPR is big on that) for a tax write-off. Those push, pull, or drag deals are just marketing. Remember whatever marketing the dealer is doing, they're always making money on it- it's a business and that's what they do. In the case of this trade offer, say your car is worth $700, they've got $1500 markup in the new car, and they're offering $2000 push pull or drag. They're going to allot $700 to your car and then shunt another $1300 of their markup over to the "trade allowance" line of the purchase order, and then they'll tell you "We're being so generous on your trade, we just can't come that far off sticker on the new car." The net result is either the same or a few hundred bucks higher for you, but it'll make the whole process much easier to understand if you just skip the push-pull-drag offer. For financing... check with your bank or credit union. Credit union is best, if you're a member of one. Tell them you're going to buy a new car and you want a preapproval on a car loan. They are going to need to do a credit check for this- no worries on this, while a credit pull does slightly affect your scores, multiple pulls in a 60 day period for the same purpose (car loan) will only affect it as if there was just one inquiry. If they give you a rate quote without a credit check they are not actually issuing a preapproval but rather just reading from their rate sheet. You need an actual preapproval because every buyer is unique and what's on the rate sheet is only an example and may not apply to you. When you have your preapproval and are talking to the dealer about payments, tell them about it and see if they can do better. "I'm approved at xxxx bank for 2.9% at 60 months, but if you can beat their rate I'll finance with you." The dealership will want to do this because they get a small kickback from the bank as thanks for the business, and it's a good thing for you because they usually get a break on the rate thanks to the volume of business they send to the bank. If the dealership's banks can beat the rate, finance with them. If they can't, then you know you've got the best possible rate already at your bank. Win-win for you. Funny example on this- PNC Bank is huge in this town and they offer special rates for their employees that are lower than what the general public gets. Thanks to the large volume of loans we send to PNC we can usually beat PNC's employee rate... financing with PNC via our finance department! For leases- just negotiate the payment. Since you're not actually keeping the car after the 3 years is up nothing else matters.The monthly payment is the only investment you'll make.
- 8 replies
- Price
- Dealer incentive
(and 5 more)
Tagged with:
Dash Odmeter Zeroed?
This. You're playing with fire changing an odometer reading. When you go to sell the car you'll be seen as much more trustworthy if you just document the engine install. Make a little packet with a couple photos of the install, the date, and a dated shot of the odometer. As someone who's bought many older cars, a 30 year old car with only 10,000 miles on the odometer and the seller saying "I set the odometer to zero because the engine was brand new!" is a HUGE red flag for me- my first thought is "what else did they hide?" On the flip side, documentation like that would earn major brownie points and make me more willing to pay the asking price, since I'd feel like the seller is trustworthy and meticulous in caring for the car. Note- nothing personal against you here, just saying this is what you're potentially getting yourself into. -
Honestly you're better off working through email. On the phone they're going to try their damndest to get you to just visit the dealership. You can do much of your research without contacting the dealerships. Once you're about ready to make a buying decision: Check TrueCar to find out the approximate going price for the car you want. Browse the websites of dealers in your area and see if they have what you're looking for. Autotrader.com is a great aggregator of multiple inventories- you can use it to see most dealers' offerings in one place, then jump out to their own site once you see something interesting. If a dealer has what you want and it's priced at or below the TrueCar range, contact them and confirm the availability of the car and the details of the price, then make an appointment to visit them if it all looks legit. You probably won't find them advertised like this though. When you see a car you're interested in use the little "contact us" or "get a quote" button (or whatever they labeled it) to reach out to them. Tell them you're ready to make a purchase within the next (day? two days? week?) and you'd like to know their best price on this car. Shop multiple dealers, but don't bother with the "I'm shopping you against 5 other dealers!" line- they already know you're shopping and quite honestly the people that use lines like that tend to also be the flakiest customers and therefore aren't given much of the salesperson's effort. Just contact them and see what they get back to you with. 40-50% of the dealerships won't answer your question. Cross them off your list. If a dealer meets or beats the TrueCar price off the bat, just make an appointment to visit them (ask for the person who emailed you!) and go check out the car. If everything jives with your expectations and they treat you well, buy it. If they try to change the price on you, leave. If nobody comes back with an offer in the TrueCar range, make a counter offer. So let's say TrueCar is $22,500- offer a little below it so they'll hopefully counter right in the range you want to be in. "Thank you for getting back to me. If you'll sell this car for $22,000 I'll be in (tonight? tomorrow? Saturday?) to buy it." This is not a contract. If something turns you off about the dealership once you get there you are under no obligation to purchase. If someone meets your offer, make an appointment to go visit them (and ask for the person who emailed you), test drive the car, and complete the purchase if you feel comfortable. Always test drive the car even if you know it's what you want. Cars are machines and even new ones are broken sometimes, and you don't want to find out there's a squeak in the interior after you've plunked down five figures. If nobody meets your offer, make an appointment with the lowest priced dealer (as usual, ask for the person who emailed you), tell them you think we're really close to making a deal and you'd like to check out the car in person. Once you've test driven the car and are talking numbers, make your offer again. "I'll buy it right now if you sell it for $22,000." Once you've gotten to this point you will almost always end up getting the car within a few hundred bucks of where you want to be. As usual, be prepared to leave if something about the way they're treating you turns you off. Are you planning to finance, and are you trading in a car? I can help with that too.
- 8 replies
- Price
- Dealer incentive
(and 5 more)
Tagged with:
Dealer employee here. I spent 6 years in sales and I've got another 3 1/2 in marketing (not Subaru though). You will not get the kind of discount on a Subaru that you'll get on a Chevrolet. In fact you'll almost never see the kind of discounts on an import car that you'll get on a domestic. Domestic brands rely very heavily on volume and fleet sales. They also are very closely tied with the UAW at their factories. Between these two factors the supply almost always outstrips the demand. They'll build vehicles like crazy and then throw out huge incentives when the supply of vehicles starts piling up. Trucks are given much larger amounts of markup than other vehicles. I'm not exactly sure why, but I can tell you regardless of manufacturer incentives we've got twice as much room to discount a $40,000 Ram compared to a $40,000 Jeep. The fact that domestic brands sell a HUGE amount of trucks compared to other vehicles means their average discount is pushed incredibly higher vs. other brands that aren't so truck heavy. There's a difference between dealer discount relative to invoice and manufacturer incentives. That $5000 your friend got off the Chevrolet was mostly incentives, I guarantee it. An example: one of my stores can get you over $6500 off the sticker price of a new Jeep Patriot. $5000 of that is money provided by the manufacturer to incentivize sales of the vehicle. About $900 of that is dealer markup, or the amount of money between sticker and invoice. The other $600 is holdback, which is the amount of profit the dealership has below invoice. If Jeep wasn't essentially giving people money to buy new Patriots we'd be able to go about $600 below invoice before taking a $0 profit deal... and bingo, that's almost exactly what you're finding with Subaru, isn't it? Subaru, like most other import brands, has a very healthy demand for their vehicles relative to the supply. They don't put large incentives like this on them because they don't need to. People will buy them anyway, and people will buy them fast enough that the supply of cars doesn't back up. Some domestic vehicles are like this too- you almost never find a large discount on a Jeep Wrangler because the demand is great enough to keep the cars moving off the lot. For the most accurate info visit TrueCar.com. You will not have to give out personal info to get an idea of what fair prices are. Just pick your make and model, put in your ZIP, pick your options, and it'll spit out an average sale price for the car. At around that price you're getting a good deal. Below that price you're getting an awesome deal. I've kept an eye on TrueCar religiously for the past several years and it's almost always accurate to within a couple hundred bucks. Let me know if you need advice for shopping/making an offer. I run the online marketing department for 5 dealerships and can give you advice for getting the best deal with the least headaches, and also the red flags for not wasting your time with a specific store.
- 8 replies
- 1
- Price
- Dealer incentive
(and 5 more)
Tagged with:
Old School Japan 4WD Non-Subaru Picture Thread
Wagon Wagon replied to Rust's topic in Non Soob Cars and Bikes Discussion
Don't forget the little ones. -
Did someone say 4WD vans? -
Minivan Advice: Chrysler vs. Honda
Wagon Wagon replied to jmoss5723's topic in Non Soob Cars and Bikes Discussion
OP was asking about the 2001-07 vans which are an entirely different animal from the 08+. With the 08+ body style many of the issues were rectified- the rust isn't so much of a problem and the transmissions are much, much better. Interiors are full of hard plastic and kind of chintzy but not that bad. When they refreshed it in 2011 the interior quality got incredibly better and they switched to a world-class powertrain with plenty of power and decent fuel economy considering the weight of the vehicle. Safety is great with plenty of airbags, high-strength steel chassis, and electronic stability control. The 01-07 vans are cheap for a reason. EDIT- oh hey I just noticed you're also in Pittsburgh. *wave* -
Unlike the airbag and ABS lights the gas light does not come on when you turn the key. You also have to get the gas level pretty dang low to make it come on- I've had some pretty tense moments wondering if and when mine was going to come on, never did see it until I parked the car on a steep hill while it was almost empty.
I've worked for a dealer group that has 3 Chrysler franchises for the past 9 years. You can buy two Chryslers for the price of one Honda and it's still not worth it. The Honda will last 4x as long. Build quality on the Chrysler/Dodge vans is abysmal. Not only will you deal with all kinds of random things breaking as well as premature rust on the rocker panels/wheel wells, it's also a guarantee the transmission will fail. They are very poorly designed and even the rebuilt ones tend to explode before 100k miles. And I do mean explode- what usually happens is one of the planetary gearsets fails at speed and blows a hole in the side of the transmission case. Safety-wise there's no comparison either... the Honda is light years ahead of the Chrysler. The Honda van will be expensive but it's worth every penny. -
So... a little talk about retrofitting cup holders. I don't like the cup holders in my 02 Impreza- the one in the console is too small for anything larger than a Red Bull can and the one on the dash is awkwardly placed and frankly just kind of weird. Every day when I go to work I bring my coffee cup and water bottle, both of them are about the diameter of a 20oz soda bottle and I only have a slot for one of them, so that means my water bottle is usually left to roll around on the seat. And that begins my search for a better one. Has anyone else found a good solution? Here's what I'm looking at... 1. The cup holder out of a mid-90s Ford Taurus. I already have one of these lying around the garage and tried it out yesterday. Not only will it not fit in the dash without trimming (it's slightly larger than a standard DIN slot) but the cup holders won't hold anything larger than a can of Coke. Won't work for me. 2. One of these things from eBay. They're inexpensive and readily available, and fit a standard DIN slot. So I know it'd work, but I have no idea if it'll hold my coffee and/or water. I can't find any dimensions of the cup holes or any testimonials from anyone who's actually used one, other than "a big gulp won't fit." But my stuff is smaller than a big gulp. Has anyone ever used one of these? 3. Cup holder from a Mk4 VW Jetta. It definitely would hold my mug and water bottle, but I'm not sure how I'd install it. It's a half-DIN so I'd have to buy a plastic tray to fill the gap. Then there's also the problem of physically mounting it, since it's held in with clips in the VW there are no screw holes. Anyone ever tried this? I know it's also possible to replace my console with that of an 04+ Impreza but it's a hell of a lot of work and honestly not worth the trouble IMO. Anyone have any other input on cup holders? I know we've got some tinkering gurus in here!
Thanks for the input. Probably will try a synthetic gear oil and see how far that gets me. Any other symptoms to narrow down the front vs. center diff? I remember having binding issues when the center diff went bad on my 4EAT Legacy but I understand that's a whole different animal from a manual. Also- tips on the visual inspection of that center diff? The whine sounds like it's coming from the firewall area, FWIW. Edit- just realized after I posted that the center diff would be approximately next to my knee, so duh, of course the sound would seem like it's coming from in front of me.
So my 02 Impreza 5MT is suffering from differential whine, which I see happens fairly often in these cars. I know this is only prolonging the inevitable, but is there anything I can do to keep it hanging on a while longer/keep it from getting louder? Special gear oil or anything? I've already got one very dead car in my garage that I'd love to put back together and drive out of said garage before I have to drop a transmission.
Just a little clip I shot while replacing the U-frame on my Impreza: http://i.imgur.com/5nIxxUA.gifv Raining rust is no fun!
If it's anything like my 1994 there will be a ribbed rubber hose looking thing about as thick as your finger going from the roof to the top of the hatch. Pop that off of the metal (you can probably do it with your bare hands) to expose the wiring, and if you tug it out a little bit you should see the plug.
