Everything posted by ericem
Oil pan screws
ericem replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
After I rtv the pan I only tighten the bolts by holding a short extension in my hand I don't even use a wrench. Even if you took off the bolts that rtv holds on pretty tight. -
Mine was the exact same way i would idle till it warmed up and the fans would cycle start driving it bam exactly what your talking about. I was searching for months and posting sooo many threads about this problem because it would drive me crazy I replaced my rad, 3 oem thermostats, rad caps, running lines differently etc. Blowing out the stop leak crap from my heatercore fixed it. IMO I wouldn't put another dose of subaru conditioner this round.
I had this exact same issue with my old legacy I found my heatercore was clogged if you look at a coolant diagram it bypasses through the heatercore when the thermostat closes. What I did was flush the heater core back and forth with a hose, including filled it with water and again flushing both ways express with 100+psi of compressed air and I saw little pieces of stop leak that were clogging the cores. Just incase though I assume your using a new OEM thermostat. I also replaced my ecu coolant temp sensor multiple times as well as thermostat's because it drove me crazy! You can still replace the temp sensor anyway since it's not a bad idea to replace it. Another question a/c is off i assume
Just a update the rear is all straightened up replaced the bent hub and installed new strut perfect! Now back to the front. Looks like the mount on the crossmember for the control arm is off by 1/2-1" . Also keep in mind the motor is actually sitting slightly sideways. The driveside of the engine is sitting slightly closer maybe 1/2" to the rad which makes no sense IMO. I am now wondering are the bolts bent or the crossmember itself? How do I remove the bolts or studs I mean for the xmember just so I can atleast check them to see if they are straight?
Guess no one experiences the hub being bent? The laterals and trailing arm show no signs of damage or bent just there is alot of positive camber even with a new strut its the same. It is hard to tell but it does appear the hub is bent I just wanted to hear someone else has experienced this or else I am thinking there is something else bent severely.
Hey guys just want some opinions I am going to tackle fixing my friends 2000 impreza rs he hit a curb at "unknown speeds" and right now looked like front control arm replacement possibly crossmember as well, rack, swap bar and endlink, struts all around ill be doing wheels. In the rear he hit the curb as well looked like it just needed a strut only. Now reason I am thinking he needs a new crossmember is because the motor is sitting like a 1cm sideways id say. I am either going to swap in a crossmember from a 92 legacy turbo or I am thinking possible the bushing for the crossmember have been damaged. I am curious what others have found in similar repairs. I will post some pics tomorrow.
Gas smell
ericem replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Hmm id be interested in a good inspection of the exhaust manifold for leaks too. -
Gas smell
Do you have any exhaust leaks? Any recent work done to the car? -
Yes I support the wrx 5spd atleast 03+ when they brought in the RA gear sets updated syncro's etc. My friends 04 wrx SOMEHOW even after going through 3 clutches in under 200,000km drives perfectly fine he abuses it all day long with stage 2 how quite a while and now vf39'd. One thing I did make sure though was keep the original transmission mount people believe the slack in that mount is bad I think that is a bunch of BS it needs that nice soft mount to jello up hard shifts etc...
Don't put that stop leak crap. Sounds like the oil pump is probably leaking that's what I found in 2 occasions I have never found cam or crank seals leaking to be honest. Even on a 90 legacy. There is one o ring on the oil pump that I found to be bad in 2 cases other cases were the rear oil seperator plate even the aluminum ones but I replaced both covers with updated steel plates with new screws. Always used just ultra grey to seal everything.
Agree sounds like dead alternator and just letting it sit let the cells in the battery even out which gave it enough to start. Another thing which my friend experienced was the ground for the engine wasn't making contact so the starter wouldn't work and would cause sensors to give messed up data so CEL etc.
