5
83subaruGLchick last won the day on September 1 2020
83subaruGLchick had the most liked content!
About 83subaruGLchick
- Birthday 12/24/1995
Gender
Female
Location
Reno Nevada
Referral
Google
Biography
I love this forum almost as much as I love my 83 GL
Vehicles
1983 GL Wagon 2007 Subaru STI
Recent Profile Visitors
1860 profile views
83subaruGLchick's Achievements
USMB is life! (4/11)
51
At this point I’ve read 2 of them at least a dozen times collectively…. At a major stand still and can’t figure it out.
I have a pin diagram but they don’t number up to 85 or anything it just goes through like 1-26 depending on the size of the pigtail? Am I just stupid? Can someone PLEASE shed some light on this. I feel like a idiot and am so beyond frustrated with this whole thing I DONT KNOW ANYMORE
Does anyone have a diagram of the ECU pins? I’m chasing the same problem in my swap. I have a 83 GL I’m putting an OBD1 EJ222 out of a 92 legacy in. Not getting any pulse from the ECM to the injectors I’ve gone over the wiring over and over. Got the harness trimmed by SJR but he left a lot of stuff not labeled so I’m not sure what everything is…. Engine was in a AT but I got the right ignition coil for a MT… might be worth mentioning I wired my fuel pump to a switch for more anti theft, hoping there’s no way that could be the cause for my headache… getting to the point where I want to push the car off a cliff and cut my loses. Any help is alpreciated
Good Morning Everyone, Another update!! The car is SO CLOSE!! Check out my Instagram @83adventurewagon for updated pictures since I cannot post anymore here... I have the new tires on, the transmission in, the new custom aluminum radiator in(working on plumbing currently), the custom air intake, the new driveline, the custom made exhaust, new bushings all the way around, new off-road lights, and the interior almost put back together but before I finish that I am going to make sure it starts with no wiring issues. I am currently having some starting issues I have not quite figured out what all is wrong yet, although it seems fuel related so I have some things I am going to try this weekend to see if I can get it worked out. The car is so close its on its own weight and ready to be driven!
83subaruGLchick started following el_freddo
What color is your early 80's dash clock
83subaruGLchick replied to Subi81's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My 1983 GL Wagon Base model nothing fancy has a green clock. And orange dash lights but white gauges with no illumination. -
Speakers in front doors installed with grilles so they’re protected. I ran the wiring through the factory grommet, I just cut a small hole so that it protects against water still. I also ran the wiring through loom for longevity purposes.
Hello all! I realize it has been a long time since I have updated anyone on here…. The car is still not done :/. I know I should have finished it by now but life got away from me, needless to say I am focusing on it hard now and want to have it at least firing by August 1st! I have the engine installed and wiring in, lately I have been finishing up other wiring on the car like a backup camera, the radio, the new coolant and oil pressure gauges, and everything I also have other things to button up wiring wise then clutch in, transmission in, driveline built, exhaust done, intake piping, and other misc engine bay things! I am trying to take my time and not cut any corners on this build but it will all be worth it in the end!
https://www.facebook.com/83adventurewagon/photos/?ref=page_internal I have a Facebook page that has an album as well and an instagram build page if you guys want to see more pictures! @83adventurewagon
Here is the engine bay now, on the far right is the fuel filter, still don't have the flywheel but when I get it the transmission will be able to go in.
Using the stock fuel filter mounting plate after I cleaned it up and painted it here is me installing the new fuel pump, filter and fuel pump relay which I then loomed the wiring and tucked it and ran it up the transmission tunnel to the engine bay.
Good Morning Everyone! Just wanted to post an update with y'all since I haven't posted in a while on here on where the car is at... I have started the EJ222 swap but I am doing a lot more than just that, I am also putting in a 5 speed dual range and upgrading and adding a bunch of other things too I won't be able to list every little thing because I honestly don't remember every little thing but as I go I will talk about quite a few of them. First things first; The next 3 pictures are of when I took the stock fuel pump, filter, and hoses out of the car and replaced them with a universal fuel pump, fuel filter and 5/16's fuel injection lines and clamps. I have also installed a cool fuel filter in the engine bay with the engine that you will see uploaded here as well. I will also upload pictures of the dash and other random engine bay interior pictures of where I am at. Currently the entire dash is out of the car, I am redoing all of the foam under the dash for the HVAC system as well as the dash pad just for mounting it and noise reduction. I AM IN SEARCH OF A HVAC PIECE THE ONE THAT HAS THE BLOWER MOTOR IN IT MINE IS ALL CRACKED WHICH IS WHY I CANT CHANGE MY BLOWER MOTOR LOCATION. Currently working on tying engine bay together and interior which consists of soldering wiring together, tucking, cleaning and figuring out where I am routing stuff(like my engine bay fuel filter that took me a while) and like next is where I am going to route my air filter. I am not going to put my dash back on though until I fire it and make sure wiring is proper and everything works. I am installing an aftermarket voltmeter, oil pressure and temp gauge, all other gauges are staying stock. Also will be installing aftermarket stereo, speakers, cigarette lighter, and switch port. I will upload a picture of my gauge cluster as well. Exterior wise I will be doing different tires and a front bumper for sure since I have no front bumper of any type right now.
