OswaldtheBold
OswaldtheBold last won the day on October 31 2019
OswaldtheBold had the most liked content!
About OswaldtheBold
- Birthday 01/01/1960
Location
Grand Junction
Vehicles
1997, 2012
Recent Profile Visitors
OswaldtheBold's Achievements
Advanced Member (3/11)
13
That is not a good noise! Hard to tell from your video, but do you think the noise is coming from the transmission? How many miles on it? Take it to a Subaru dealer. The CVT trans has a 10 year-100,000 mile warranty. My 2013 was having a torque bind problem. Took it to the dealer last week, and they replaced the transfer clutch piston and plates under warranty, and said if I had any more problems they would just replace the entire transmission. Hard to say if the warning lights are related to the noise. I have never had any warning lights come on after startup.
The Subaru dealer's opinion: "confirmed customer concern, transfer clutch is not releasing properly, causing a tight binding and rumble noise on sharp turn. Removed transfer clutch and plates looked discolored like they were getting hot." They replaced the transfer clutch plates and piston, retainer spring, seals, snap rings, shims, oil seal, and changed the CVT fluid. "Test drove, noise and feel felt better but still a little present, transfer clutch needs to finish breaking in." It was all covered under the CVT warranty. They said drive it for a few weeks, and if the problem comes back, they will replace the entire CVT with a new one, under warranty.
OK just got back from the parking lot. Slow speed tight turns (steering wheel full lock, but not held against the stop) There is a regular periodic chirp from the outside front wheel, and a slight jerk of the steering wheel (not me!) corresponding to each chirp. The chirp period seems to vary accordingly with speed changes, but I really did not have a very broad range of speed to play with. It happens in both right and left turns, and the noise definitely comes only from the outside wheel (I had both front windows open and could tell the difference in which side it came from). The fact that it happened turning both ways, and the noise was from the outside wheel, would seem to rule out wheel bearings as a cause (unless both were bad, which is hard to imagine). Very difficult to tell if the car was slowing down in the turns (requiring more gas). If I let off the gas, the car slowed down, but I did not have to increase throttle to maintain speed. I did try driving straight ahead to get up a bit of momentum, shifted to neutral and turned. No apparent difference. The chirp was still there as the car rolled through the turn, and slowed down (but not drastically so). Odd thing about the noise: If I had not been driving a tight turn in a parking lot, I could as easily have described it as a metal-on-metal chirp as a tire chirp. It did not sound the same as the tire chirp I had heard other times. But, the parking lot had recently been resurfaced, so that could have been the interaction if the tires with different pavement surfaces. Also, did not notice the rumble noise as much, but that could be because I did not accelerate out of the turns much (tight parking lot), and I was focused on maintaining speed (and the chirp). So. I did not give it too much throttle. Still think it is torque bind?
As far as I know, they are original. I bought the car used two years ago. It was a trade-in for a new one and had only been serviced at the dealer, so I have all the service records. No indication of any previous problem with CV joints or axles. My experience with wheel bearings is they usually only make noise on the outside of turns, and I have never had a car that had both front wheel bearings go out at the same time. This new noise appears to be turning in both directions, so bearings seem an unlikely cause.
Thanks. I did not think there was a viscous coupling in the front, controlling side to side torque, but there were two responses suggesting viscous coupling, so I was just brainstorming possible causes. I did not mean to ignore your questions. Yes, tires are all the same size, same age, same wear. I have not had a chance to try your suggested diagnosis checks yet. The rumbling noise first became noticeable this week, but earlier I thought I had heard some tire chirp making a turn into a parking lot at about 20 mph and accelerating out of the turn, and wondered what was causing it. There was another suggestion of inner CV joint. Boots appear to be intact. Do you think this may be the cause?
2013 Outback, 57,000 miles. Rumbling noise/feel from front end in tight low speed turns (parking lots). Does it turning both right or left. Only does it when applying throttle. Doesn't do it when sitting still and turning wheel (apparently not the power steering pump or rack). No indication of anything rubbing anywhere. CV boots look good. Any thoughts?
I have a 2013 Outback, 2.5 with CVT. My sailboat trailer weighs about 1000 lbs fully loaded, no trailer brakes. Owner Manual says this is within max limits. Is this really doable? I live in western Colorado, elevation about 4500 feet. Mountain passes can be a bit more. I never tow my boat over 55 mph. I don't want to kill my Outback, but it sure is more comfortable than my 30 year old Landcruiser (my main tow rig).
Possible, but I did notice that when I hold the center vent open, there is still a noticeably stronger airflow through the vent by the driver's door than the center vent. The other thing that makes me curious is the air inlet selection button. When I switch from outside air to recirculate, the indicator light comes on, but the sound of the airflow doesn't change. In my old 1997 Legacy, it was much louder on recirculate that outside air.
I just bought a 2013 Outback, with the Automatic Climate Control. Whenever I turn the fan speed up past 1 (in face-level ventilation mode) or past 2 (in bi-level mode), the two center dash vents close. The little Open-Close thumbwheels snap over to the closed position, and seem to be held there by spring tension or air pressure. I can hold them open by hand, but they snap back to closed if I remove my hand. Also, I do not seem to get much airflow to the driver's side feet, regardless of the mode setting. Is this normal? I did not notice this when I bought the car two months ago, but it was in the 60's then, and I did not need either the heater or the AC, so I really did not test them out.
At least in my case, I don't think the problem is moisture in the brake booster. I had the booster replaced with a new one, and the problem was essentially unchanged. I consider it unlikely both the old and the replacement boosters were exposed to conditions sufficiently similar to cause the same problems, while my other '97 Legacy parked next to it has never had this problem. I am leaning towards the check valve theory, but haven't had the chance to try it yet. Anybody know the cost of a replacement valve and hose from Subaru?
