Tha_BluJay98
Everything posted by Tha_BluJay98
Thats why I did it in gravel and dirt. Still a bad idea nonetheless, I'll look again at the main plugs near the battery in the morning. I got an offer for a 2001 suburban with 165k because my buddy is a subaru fanatic so that's something to look into. Running and driving truck for a non running bru. The subie is just awesome though
I've been chasing wires all day looking for something broken or disconnected to no avail. I'm about ready to get rid of this thing.
The only bad ground I could find was that one and I attached it to a bolt on the tranny case. I also replaced the coil pack.
So far have replaced, knock sensor, timing belt, crank positioning sensor, ecm, ignition control module, plugs, wires, throttle positioning sensor, injectors 3&4 and still can't get spark. Very upsetting.
It just cranks and cranks but not turning over. Day 5 of troubleshooting. Very irritating
Nobody can Tell Me where this ground is supposed to go? I've been looking at engine bay pics for over an hour and can't find where it's supposed to lead
All of the wires are fine down by the battery. Tracked them to where they connect and see no issue
Ignition control module possibly? Seems like the only piece that controls spark that I haven't replaced so far.
3 hours of work tonight, multiple more during the parts replacement yesterday and the day before. I don't even know what to do at this point.
I set the timing perfectly all hashmarks at 12 a clock and it still only cranks and cranks no start. Very upset that my 3 hours of work and tons of parts replaced in vain. Once I finally get this thing started I'm grandma driving for awhile.
Do the hashmarks have to line up perfectly? If not it looks like I skipped one or two teeth
Is there any posts instructing how to set the timing? After inspecting my belt it seems solid.
This is the only ground I could find that was not attached to something. Where does it go? I tried to find where it's supposed to lead to but I couldn't find it
Update, I replaced the Knock sensor, crank positioning sensor, throttle positioning sensor, ignition coil, and every relay in the box. Checked my timing belt and it's still new looking. It still won't get spark in any cylinders. I tracked down nearly every plug and wire to see what could have happened. I found one bad ground coming off the middle of the firewall but couldn't find where it went to. So very stumped about what is going on.
