Larsen Autoworks
Everything posted by Larsen Autoworks
  1. Personally when we are rebuilding a motor here at the shop we order a gasket kit and replace all gaskets. Its better to have piece of mind when using new so you don't have to worry about any leaks. We typically use cometic, its a good quality set of gaskets and not too hard on the wallet. I'm glad to hear your going to go ahead with a swap. With the overheating issues you had with your previous motor overheating I would have been concerned with the block/cylinders being warped from the heat.
  2. The clunking sound, do you hear it all the time while accelerating or just during shifts? How do your trans mounts and pitch mount look? If somethings rocking it could cause the sound youre hearing.
  3. Hello fellow Flat 4 enthusiasts!!! On behalf of us here at Larsen Autoworks I'd like to say hello!!!! My name is Rick, I'm the sales manager here and will be keeping this account up to date. Little bit about me, I'm a certified EMT in New York and work for the Northwell Healthcare system. On the side I do stunt driving on tv shows and movies. As a hobby, I manage the wholesale accounts for Larsen Autoworks. https://www.facebook.com/LarsenAutoworks/ Instagram @larsenautoworks More importantly, MY CARS!!! 2015 WRX IAG EGR deletes Cobb Intake Invidia catless J-Pipe Magnaflow Exhaust Grimmspeed ebcs Mishimoto Top Mount Mishimoto Charge pipe Cobb Accessport protuned conservatively at 276whp/303wtq 2008 Forester XT Power: FP Red with 10cm hot side Gates racing timing belt Brand new ej257 case halves King bearings Manley H-tuff rods Manley pistons STI heat treated crank Port & polished heads - gasket matched Grimmspeed large top mount SPT Heatshield PTP Turbo Blanket Walboro 320 FP Grimmspeed EBCS Tsudo exhaust Agency power elh SRS 3.5" Catless dp Turbo xs up pipe and dumptube Suspension/Driveline/Steering: 07 sti drivetrain swap with 6 speed RCE Black Springs Paranoid Fabrications 3/8" Saggy Butt Spacers Perrin 25mm Front Swaybar Perrin 22mm Rear Swaybar Perrin HD Mounts Kartboy F/R Endlinks Kartboy Diff Outrigger Bushings Kartboy Botox Bolts Kartboy Tranny Crossmember Bushings Whiteline RCA Roll Center/Bump Steer Kit Whiteline Com-C Strut Top Mounts Whiteline Lateral Link Tab Supports Whiteline QR R Strut Bar Whiteline Steering Rack Bushings Whiteline F/R Camber Bolts Whiteline Offset ALK Bushings STI GroupN R Strut Mounts STI GroupN Pitch Mount STI GroupN Tranny Mount SPT Front Strut Bar Superpro F/R Trailing Arm Bushings Cusco Lower Arm Bar Tires/Wheels: Brakes: STI brembos STI Master Cylinder STI Brake Booster Goodridge SS Brake Lines Cusco Master Cylinder Brace ATE Superblue Fluid Interior: STI Seats STI Steering Wheel STI Floor Mats CG-Lock Bling: SPT Battery Tie Down STI oil cap Subtle Radiator Shroud Subtle HVAC Overlays Subtle TMIC Shroud STI JDM Hoodscoop STI License Plate Shroud STI Badging Hella Horns Vinyl Wrapped Rear Window Trim/Roof Rails Morimoto Bi-Xenon 35w Retrofitted Headlights w/ 4300k H1+ Mini Gatlling Gun Shrouds Not finished with the build as of yet so I can't post numbers. photo links: http://i.imgur.com/psfzgFY.jpg http://i.imgur.com/sQWbA9W.jpg http://i.imgur.com/10MlaKX.png http://i.imgur.com/AtPTIVW.png
