Ubatz
Everything posted by Ubatz
Update, I was thinking of something else. I haven't done anything to the CTS. I've also heard the VSS can be a problem causer for this?
- 4 replies
- 1991 subaru legacy
- iacv
(and 1 more)
Tagged with:
I had it in a shop for the tps. They calibrated it for me. Thermometer and coolant temp are all working properly. And were recently replaced since they're a common problem for the car in the first place.
- 4 replies
- iacv
(and 1 more)
Tagged with:
I have a 1991 Legacy with code 24 and it would not fire on cylinder one as per the usual in limp mode with said code. I replaced the tps and now it fires on all 4 and it's a new pre-calibrated IACV. Is it possible calibration is off? All the wires have been rebuilt/replaced that got to the iacv. I put in a new ecu and it runs a tad smoother now at least. Symptoms: -Cold engine must be revved to about 1.5 to 2k for a few seconds so it's a tiny bit warm to run decently enough. Warm engine is fine. -Idle is higher than it usually is. -Automatic Tranny; Shifts to soon and makes it bog and struggle to speed up -Overdrive engages and stays engaged until under 40 mph which it never did before. [Symptoms are the same across both ecu's except the old onw just made the idle a tad rougher.]
- 4 replies
- iacv
(and 1 more)
Tagged with:
Clearing the code and resetting the ECU again has made it slightly better but the issu still exists so I need to check the wires. I'm hoping it's a bad ground cause that's probably the easiest to fix honestly.
- 11 replies
- Check Engine Light
- Idle Issue
- (and 3 more)
Yeah, I don't have the tools that he has. So I'll use a voltage meter if I have to.
- 11 replies
- Idle Issue
- (and 3 more)
Thanks! I kinda get an idea from those. I'm gonna try to let the engine warm up and go for a short drive. and if it doesn't change I'll test power ground and the sensor wire [three wire system]
- 11 replies
- Idle Issue
- (and 3 more)
It's a 1991 Legacy with the NA ej22 and an auto transmission.
- 11 replies
- Idle Issue
- (and 3 more)
It's a code 24. Two long flashes and 4 short ones. the iacv is seperate from the throttle body etc.
- 11 replies
- Idle Issue
- (and 3 more)
I recently replaced an idle air control valve and the check engine light is still on and the idle is still rough. Do I need to reset the ecu? Or do I have a faulty wire? I'm a bit unsure because normally I've never had to reset the ecu.
- 11 replies
- 1
- Idle Issue
- (and 3 more)
I replaced my Idle Air Control Valve on a 1991 subaru legacy. The CEL had indicated it was bad, after I put in the new one it still was on. Do I need to reset the CEL [OBD0] or do I just have a faulty wire?
I know I leak a little grease and that's getting fixed this Wednesday. The solenoid works sometimes but mostly not. It works on hot days abd I figured that would be because the fluid is less dense from the heat. Cause gear changing had become sluggish as well. [i work a part time job at 17 and am an aspiring mechanic. So flushes aren't easily in my budget.] I was recommended that it might just be a short. The pan looks undamaged but I'm gonna have it inspected. It's hard to find the part on my own so I may leave it to them.
- 8 replies
- legacy L
- Transmission
- (and 4 more)
Thankfully my transmission isn't as complicated with the temp sensors. However, you could be right. I'll get it flushed and taken apart and cleaned. Then I'll have them check the wiring if that doesn't work after a little bit. it DOES have 300k miles
- 8 replies
- legacy L
- Transmission
- (and 4 more)
Last I checked it was starting to get a bit dark cause I thought I smelt it Burning. It does have that smell on rare occasions. Usually on Long trips
- 8 replies
- legacy L
- Transmission
- (and 4 more)
Yeah, that's how I figured out what it was. And then learned more when I had time. It flashes a code corresponding to duty solenoid B.
- 8 replies
- 1
- legacy L
- Transmission
- (and 4 more)
I have a 1991 Subaru Legacy L with the standard 4-speed automatic transmission with lock up. Duty solenoid B within the transmission is responsible for the lock up however it's been failing or not working at all for a little while and when it does work it is weak. The transmission could probably use a good flush but I don't know if that would solve my problem at all Maybe the weak problem but I'm not sure if there is a short or something causing the transmission to not lock up or if Duty solenoid B is just dead.
- 8 replies
- legacy L
- Transmission
- (and 4 more)
Check coil packs?
Ubatz replied to Ubatz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I'm unable to find the page you told me about. I'm on a mobile phone which probably doesn't help. -
Check coil packs?
Woops yeah I forgot to do that. 1991 Subaru Legacy L N/a -
My ecu didn't give off any codes. Not even in the memory except for 3 short flashes but that didn't show up as an actual code
I found that when I drive it a bit more to around 3000 rpms til it shifts it actually gets slightly better than normal. I grandmaed it and it lugged a lot. It doesn't like lugging. So that's helped a tiny bit
The engine doesn't feel sluggish and it runs pretty good other than an erratic idle sometimes but I think that's just because it needs to be cleaned a little bit and it's very rare that it idles weird. I looked into it and it doesn't seem like it would be a problem considering the symptoms. When I first started my car if the engine was warm and it was really cold out and occasionally it would like flash on her stay on for a few seconds but nothing more than that. I might go into my ECU press the button and get the morse code flashes to see what might be up.
I'm not sure where that comes into play. I will check to see if there's parts for it. Where is it usually located?
