Groucho
Everything posted by Groucho
aftermarket fuel tank for 86gl wagon?
Groucho replied to Groucho's topic in Old Gen.: 80's GL/DL/XT/Loyales...
thanks bennie! yeah, that’s kinda looks like what my options are .. $1000 fuel cell, $500 surge pump setup. actually i think you gave me the answer i needed- junkyard EFI tank. hmmm -
hey! i’m finishing my ea to ej swap and wondering if anyone has recommended an aftermarket baffled fuel tank that fits the gl wagon? i replaced the fuel pump & lines and i’m worried that the more powerful pump will cavitate with a 1/2 empty tank, especially uphill. thoughts? thanks, groucho
heeeeeey. i’ve been lurking the forums since buying the murder machine in 2017 & getting so much info from y’all thought i’d finally post some photos. 1986 gl wagon, ea81 swap with weber conversion, 4 inch sjr lift. 6 lug conversion currently running 215/75/15. all the interior lights have been deleted, & the cooling fan is on a toggle - i live in leadville so it’s usually cool enuf. straight exhaust to annoy the neighbors. just installed the steel front bumper & winch!
Thanks! The AC has been deleted, so I think it originally ran 2 belts. I think I'll try and replace the serpentine - I've heard some belts make more noise when there's a slight pulley misalignment and others dont - and I'll look at the idler when I'm changing it out.
I'm having the squealing problem with my ea81, which is running one belt for the 4 pully. Are you saying rebuilding the idler will help eliminate the squeak, of do I need to run the other belt? Sorry to thread jack the squeal is killing me...
Thanks that's the info I needed! I saw u post somewhere else that u run the factory struts with your lifts - u think that's the best set up? Only wondering because the mechanic I bought the wagon from said I would need to replace the struts ...
Yeah so fun! I'm living up around Grass Valley & it's basically endless fire roads..
I just hooked up a 87 GL wagon with a SJR lift and some other mods, but little info about them (and of course no papers..). I'm trying to determine which lift is on the car - can I assume it's a 3" lift if all of the lift hardware measures 3"? I was also told I would need to replace the struts eventually - tho it's running fine on stock struts now. Any suggestions on the best setup? Thanks for any info - I'm new to the Subaru world. In fact, this is the first car I've owned since the 90's.
