nedro
Everything posted by nedro
Normally you will see two tiny little holes on the drum face as you are looking at it. These are 8x1.25mm bolt holes. Spray a bit of WD-40 into them and insert a bolt in each one. drive them in with a wrench little by little and evenly. Your drum will pop off. They are there for this exact reason.
Go to www.subaruparts4you.com They make you enter a VIN # when ordering so the part is correct. Also, you can call Greg, he will look up the part for you so you can enter the actual part#. I know because I just got off the phone with him for rear brakes on my outback. Just make sure you have the VIN # when you call. He didn't know me from Adam and still was very helpful.
Older Subarus were 4-wheel drive. New ones are not! At least my 05 outback is not. Does All Wheel Drive qualify as 4-Wheel Drive when road conditions state "4-wheel drive w/ snow tires or chains required"? Simple but illusive question. Anyone know for sure? Any LEOs out there with the real scoop? BTW I'm mostly concerned with states in the Rockies and West of them. But welcome info from anywhere on the continent.
I didn't ask for best price & service, but since you mentioned it; My local parts counter guy presents himself as an incompitent moron with a lazy additude and a general lack of automotive knowledge. I've never seen him walk at a normal pace. I've never seen any initiative out of him. I special ordered a part for the rear trunk cover that turned into a nightmare. He forgot to order the part the first time. The second time was supposed to be two day air (Never happened), then finally after waiting more than 30 minutes at the counter (over a week later), he came up with it under someone elses name. I was at the counter 4 times for this one item. Each time was an exercise in extreme patience (sp?). Thanks for the link WmCraven. I went with Subaruparts4you
No, it is not "absolutely" necessary to use a torque wrench. When I was a full time mechanic, I could get torque on a rim within 5 LBS. of the required torque and 2 LBS between the lugs. But if that isn't the case, I've got a question for you. Is there any torque wrench on the market today that costs more than an alloy wheel? (Sans a computerized machinist's torque wrench.) BTW, I thought good torque wrenches were in the $150.00 to $500.00 range.
