damnsubaru
Everything posted by damnsubaru
  1. where does the relay get it's power and does the ign get it's power from the same place? the car i am working on has no spark and no fuel.
  2. went and checked the car this morning. put a battery in and it cranks but no spark and no fuel. tested the ign coil and no power,checked the ign fuse its ok,checked the computer fuse it's ok while i was at it i checked all the fuses they all checked out. could it be the computer,doesn't that run everything? he is going to get a battery and a haynes manual today so i am not whistling in the dark. more to come later.
  3. i started to work on my wagon a while ago,no spark no power, found out it is a bad ground wire under the dash. got distracted and haven't worked on it much just new brake parts and wheel bearings and seals. don't tow subarues without axles in it. still trying to piece things together but the parts aren't cheap that is what takes so long. wifes projects come first. just need two drive lines and rotors for the brakes . found out there are two sizes for the drive lines. the turbo ones are a bit bigger on the tranny end. everytime i go to the wrecking yard i forget the subaru tools.
  4. used to be on this site and was known as subsub been gone while. now i am working on pastors freebe car. ac doesn't work fuel pump doesn't work,it was replaced but still doesn't work not sure how it is suppose to work. where is the fuse and relay and where does it get its power? what i would like is a shop manual but the cost money. i also need to put things back together because they took trim apart and i need to put it back together to make it look nice.
  5. my pastor recieved a 1991 legacy with a 2.2 engine in it. it won't start without a squirt of gas then it dies,i haven't tried it yet myself but was told it has a new pump in it. not sure of the filter or the relay or fuse. i am going to look at it tomarrow as soon as i round up a battery. i just need more info to know where to look. it has been a while since i worked on a subaru. i think the fuel pump relay is round but i am not sure. as soon as i get a wiring diagram it will be a lot easier.
  6. is that the same for a 91 legacy wagon. the p.o. suposedly put in a new pump but it still doesn't start so i will try to squirt gas into the air intake. where is the gas filter.
