4valvevw
  • Location
    Brisbane, Australia
  • Referral
    Google
  • Biography
    Love engines and custom stuff!!
  • Vehicles
    1993 impreza
4valvevw's Achievements
Newbie
Newbie (1/11)
0
  1. Yep thanks heaps for that. I worked out what i wanted, and ended up getting the crank and cam sensor off an ej22 - think from what i have read, they are pretty interchangeable and do the same job. Just wondering if anyone knows what position on the crank the keyway is positioned? whether its 0 degrees or between 5 degrees btdc and 7 degrees atdc....Just need to know because I need to adapt onto the "project engine" ... Cheers, Lawson
  2. Yep ok, Really need to know the ignition system for these engines, explain the basics as i have no idea! Does the ecu control the ignition? does these engines have a crank trigger? or cam position sensor? Any help would be appreciated... Cheers, Lawson
  3. Ok thanks heaps...(for some reason i am able to reply now!) Also wondering what the spark system is on these engines? (I know nothing, so explaining everything..) Is it distributor, crank trigger ect? Cheers, Lawson
  4. Hey all, Just doing a project engine (not subaru but still a flat 4!) and just need to know the compression ratio for the ej16 engines... Any help would be appreciated.. Cheers, Lawson
