Everything posted by Tony Cortado
Squeaky Pass Wheel - New Axle
Tony Cortado replied to Tony Cortado's topic in Old Gen.: 80's GL/DL/XT/Loyales...
New Mid Work Update: I checked out and took apart the front pass hub assembly. Definitely need that lube on the caliper slide pins. I decided to go ahead and (attempt to) punch out the bearings, which took way longer than expected -- in fact, the inner bearing is in there pretty good, so I'm going to have to take it to a friend that has some extra tools to help pull that bearing. Good lord, I hammered away with a giant socket for .... 2 hours? I'm sure the neighbors weren't happy about it. I attached photos of a few things -- first, photo is the caliper piston and torn boot. Then the caliper slide pin boot. Next are the brakes. I put them on probably 60 to 100 miles ago. The inside brake seems to have a gouge already. The outside brake looks ok, but I think it's wearing a little uneven. For point of view, the outside brake is upside down in the photo, and the inside brake is right side up (not rotated). Followed by the axle / spline. There was some red dust that came out when I removed the rotor. I assume it was rust, but I am not positive. You can see the red on the splines. Axle removed, you see the outer seal and bearing, followed by the opposite inner seal and bearing (all the particles were a result of the operation, and were not inside the bearing). Outer bearing out of the knuckle. Oil seal looks fantastic (not pictured). I couldn't get the inner bearing out, so I'm headed to the bus mechanic shop at the national park nearby where I have some friends working. With their proper tools, I should easily get the old bearing out and new seals and bearings in. I had to borrow my girlfriend's truck to get to work. Yep, I got the Subaru, she has the 1994 4wd pick up. Any thoughts on these photos? -
I didn't even think / realize about the caliper pin lube. I remember seeing that the caliper pin boots look good, and even make a nice "POP" sound when I slide the caliper off, so I assume there is still a nice seal. I do wipe off the misc brake dust, dirt, and rust that falls onto the pins when I have (many times), tried to find the source of the sound, but not lubed it up, so this could certainly be the source of the sound I recorded. Unfortunately the store near me doesn't have any non-oil/petroleum high temp greases in stock aside from some graphite stuff they say will work ("American Grease Stick Co. Graphite Extra Fine Powdered"). I don't know about using that, though. Gonna see what I can find after I get off work, but that's the only one store near me, hah! Question about the caliper pistons: when turning the pistons to draw them back into the caliper, should it be pretty difficult or pretty easy? I use pliers because I don't have the "special tool" that looks like a stunted street key. On the drivers side I have to use all my might to turn the caliper back in, and the passenger side (with the torn boot) is pretty easy. Thanks again for all your help, everyone! I'm looking forward to have a perfectly running Subi by the end of the summer, at the hands of a Youtube / "Armchair" Mechanic (myself) -
Thanks everyone for the replies! I'll head to town next week, a 5 hour drive. I'll pick up a hoard of parts. May as well ... Go to town, haha. Parts to replace will be: both front rotors, both front calipers, both front bearings. I already have one spare front bearing set, so I'll replace the squeaky one, front pass, in a day or two. I'll double check that I'm not missin any nuts and bolts, double check torque on the castle nut (I'll try over torquing) and report back if the squeak goes away. Thanks again! -
The squeak happens all the time, not only when turning. It happens loudest under torque, like when accelerating, going uphill, or after downshifting. It doesn't always happen when turning, and it doesn't always happen when driving forward. It's intermittent. I don't have any play in that wheel, 12 / 6 o'clock position, and both the driver and passenger side are of equal temperature when driving (fast, long distance, bumpy dirt roads, etc.). The humming noise is definitely the brake dragging a little (need to replace the brake caliper), there's no brake-scraping sound when I remove the brake, and the wheel rotates freely. I'm not ruling out the bearing -- I mean, there are only a few things that it could be, right? -
Heya Folks! I've recently acquired a gorgeous 1993 Loyale, a delicious bucket of rust, that's probably been the best car I've ever purchased -- and my very first Subaru! The issues I can deal with and fix are numerous, I just replaced the axles myself, properly torquing the castle nut. Now I'm getting a squeaky / rattling sound coming from the front passenger wheel area. It happens most of the time, but always under acceleration and higher torque. I didn't notice it for a while until I drove through a forest, the trees helped the sound echo back into the car. I took my audio recorder so you guys can hear it. Though it seems like the sound goes away when I use the clutch (there is one instance of this in the recording), it does happen regardless of the clutch being depressed. I had a look and noticed that the caliper piston boot is a little rough, and the brakes drag a little (a little humming noise) when I make a left going over 35 mph. Otherwise, everything seems "okay." ZOOM0013.MP3A Any ideas? Thanks for your thoughts!
