alexb1
alexb1's Achievements
Member (2/11)
10
can someone post some picturs of the inside so you can see the filter in it.i want to do it on my 88 dl ea71 engine, and on this engine you allso have one line to the air filter box , so where do i conect this one? one more question , on the condensator made from a beer can wat is the third litle pipe in the midle for?
hello , what do you think about this thing , is it any good? www.turbonator.com/
steering as new----finally!
alexb1 replied to pyromanic's topic in Old Gen.: 80's GL/DL/XT/Loyales...
can you axplain please what are leading rod bushings? maby a picture of it? what's the year yore car manufactured? -
you also need a special tool to shrink the spring and take it over to the new shok abzorber , on the way change the rubber protektors wheech are probably toren , at the and take the car to do a wheel alingment (sorry if i misspelt the last word). good luck!
Coloured dash Illumination?
alexb1 replied to ausubaru92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
are you sure , couse if we have the same panel and i think we do then it's not completly clear , some thing has to give the yellow colour . when i had my panel a part it had also some kind of green/yellow background, i tryed to scrape it of but it is like one asembly so i cant see how to take it of. try to paint one bulb and look if the color changes , if it does then you are wright it is clear and you can change to any colour. -
how are you going to change the green color , isn't it molded in the back? -
ok , i'm hapy to say it's all warking , i hooked up the new panel and it is great to look at the tach going up wituh the engen. so if you have questions go ahead. by the way if you can get the the plugs with the wires from the new panel ( that's what i did) then the colors to the conectors are the same.
ok, i think i figured all the wires on the panel with the tach, now the problem is to do the same on the original panel cuse nothing is writen on it , how did you do it? when you say the yello wire it is the one says "ta" on the pc, and, black and whaite is the one says "ign" . i did'nt understand were axactly to conect the yello to the coil , tere are two conectors on it which one do i need?
