Hi,
This site is great. People here are very generous with their time and knowledge; thank you. I have a 98 OBW with 166000 miles on it. I recently noticed the signs of head gasket failure and immediately took the car to the nearest dealer. They diagnosed the common head gasket problem and charged me $3500.00 to remove and repair them, including thermostat, water pump, timing belt, spark plugs and wires, work on the valves, oil pan, seperator cover, main oil seals. One week and about 500 miles (and no warning lights) later I was driving on the highway 185 miles from home, heard a crack/bang sound from passenger side. The warning lights came on and car lost power. I pulled over to find oil all over rh side of engine. I called a tow to next dealership, left car and went off in rental.
Dealer 2 who has the car, took engine out and took it apart. He mentioned that oil was leaking from seperator cover but ultimately says the right cam was oil starved and siezed causing the cam gear to break. He also says the cam cover was installed backward and things this caused the problem. Block is now warped.
Dealer 1 doesn't think this makes sense and is having car flat bedded back to their shop.
I don't know a lot about cars; does Dealer 2's diagnosis make sense? Is Dealer 1 setting up to deny fault? Any advice?
Thanks
