Contact Methods
Website URL
http://forums.nasioc.com/forums/forumdisplay.php?s=&forumid=13
Location
Spokane WA USA
Occupation
Military / College
SovereignMK's Achievements
Member (2/11)
10
Correct NGK plug number for 1.8OHC?
SovereignMK replied to SovereignMK's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I just tossed them in:-\ It's supposed to be.044 iirc right? //M -
Ok, I've checked and everything says it's the right part #. Though I'm getting a sputter like somethings not firing(guess) after changing the plugs(BPR6ES-11 was in there previously). I've pulled the wires and plugs and redid it but still a rough idle and has the tendency to die. //M -
SovereignMK posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
Is BPR6EY-11 right? //M -
engine pinging/knocking problem with EA82
SovereignMK replied to mnorton's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Oooo, Have any pics pointing that one out? Is it like the PVC valve? Rookie here, needs a map around the engine bay. //M -
I get pinging in hot weather if I run anything less than Premium on my 86 Wagon(EA82). Going to find out if it's true for cold weather as soon as it gets here. -
Fuel Door & Other Questions
SovereignMK replied to Gregg's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Fuel door anwser. //M -
Good Fix for window streak marks?
Thanks for the info, Looks like I get some new glass at the junkyard and then test the buffing on my old stuff. Will let you know. ///Mark -
For those of you that get the streaks from the rollors pushing on the window glass(power windows), have any of you found a good fix (besides replacing the glass). //Mark
XT6 Clutch Kit in '86 GL 5sp Right?
Thanks XSNRG! I remember searching for the info and coming up with that thread and assumed it was a direct swap too, though being a Brat with a EA82, I didn't know if that came into play. So basically, if I get a XT6 clutch kit (includes flywheel right?) it should pop right in? //Mark P.S. No Haven't meet Barracuda yet. But I would like to get a Eastern WA / Idaho meet together before the weather gets too bad. -
Eastern Washington/Idaho meet?
SovereignMK replied to SovereignMK's topic in Meet n' Greet. Your USMB Welcome Center
Bonners Ferry is quite a drive from Indiana:D //M -
Come on, Needing some help guys!:drunk: :-\ -
Anybody want to help a new guy? //M -
Ok, I need some ressurance that the XT6 Clutch kit will work as a replacement for my slipping GL clutch. I'm really a noob on my GL compared to my Legacy so help me out guys:D Is this a go? And what were the benefits again? Thanks. ///Mark 1986 GL Wagon 5spd with 4hi/4Lo 223000mi
