uniberp
Everything posted by uniberp
I mean at 170k miles, it's starting to sound like a diesel when starting cold, and takes about 15 minutes to go away. I hope valve adjustment is fairly straightforward, with little caps and cup things, and can be done without removing anything but valve covers. Just to get some more life out of it, and avoid popping off a valve top. No desire at this point to lift the heads.
IDK about '92, but the only difference in my 97 model year is the spring seat is about 2 inches higher in the OB. After it was all done I wished I had replaced springs as well. And the additional axle angle made my right front inner boot fail in the next year, too. But the local tire store did a good alignment cheap, so that was nice.
I have found these plugs are frighteningly stiff to remove. I did it with no trouble, but nightmare of stripped plug holes haunt me. I think I even cracked them loose, sprayed penetrant, then waited overnight, and they still felt like they needed 35 foot lbs to twist loose. I guess that's the design, aluminum heads and all. I know old BMW motorcycles have soft heads and frequently havenearly stripped plug holes because of casual mechanics.
Thanks to this board, I replaced my right front axle last night in less than an hour, without even getting under the car. Used a 36" long ~1/4" rod to knock the pin out from above. IDK if this would work on the left. Marked and undid the lower strut bolts and undid the axle nut, and it was in a and out in no time. Drove to work, still aligned. Very satisfying. Now we'll see how good that $24.95 shaft from ebay is.
1. Are you sure you replaced the ECU temp sensor and not the one for the gauge? I ask becaus ethat's the kind of mistake I make, but since your codes don't show a prob there, this is probably not it. 2. I also have a 97 Legato (Leg-auto 2.2) and had gas mileage problems. Did all the same changes as you and got it back on track. Now get 27 AVERAGE, 16mile 50 mph commute. Very happy. 3. I also still have gas smell at startup, and I think it's plain too rich for this older (165k miles) engine. My theory is that compression is down due to tired rings, so less air is ingested, but same fuel amount, based on temp only, is injected, while cold. What I want to do is put a 10k-20kohm resistor in parallel with the temp sensor, which will flatten the resistance curve. Leaner when cold, same when hot. 4. (Not likely but...) Brakes dragging? I noticed caliper piston locking on the 99 Forester we also have and that need to ba addressed (uneven pad wear indicated).
Batteries that have been run down recover a bit on their own, often enough to restart the car and go a little further. I suspect alternator AND battery. IDK if subes have a "limp home" mode, but I'll bet it's close to the 'cold start' settings, which are overrich and will bog down for a warm engine.
Here's what I'm thinking: 1. Add an ignition distributor, somehow. Some cam-end thing like on a volvo. 2. Machine a mount for a carb atop or in front of the manifold, move the coil pack a little. 3. Put in a regulator and piping 4. Mount a 10-50 lb tank on the back bumper. 5. Lock the trottle plate closed. 6. Shut down the ECU. 7. Reconnect plugs to distributor 134 cu inches, not much bigger than a forklift. We're talking Michigan here, so emissions will probably not be introduced for another 10 years. Thoughts?
