uniberp
Everything posted by uniberp
Totally caked up PCV. Had been burning oil. Now doesn't. I seemed to notice the cruise control working better (more precise and responsive, old style dash button with stem controls 1999 Forester), and that it is not shifting as hard 2-3. Does the 4EAT have a "vacuum modulator" that might account for that? The cruise thing is more obvious. high speed + low vacuum minus additional loss through PCV = poor response. On the bright side, I burned about 5 (additional) quarts of high quality oil through the engine since March, so now those new valve seats are nice and hardened Maybe.
All these are good options, but what I really want is an engine that is as quiet at startup as my 2008 Forester with 60k miles. This rattling smoking stuff is tiresome. There is one last chance that the oil rings (or other rings) are sticking, causing all this ruckus, and I may fog it with seafoam to try to clear that up.
The 99 has the smaller journals, I think, so I'm further disinclined to rebuild it. Both engines run, but this imminent "ticking" which I optimistically called "piston slap", I know recognize is rod knock. I found this company locally, I can drive up and back in a few hours: http://www.ebay.com/itm/1990-2010-Subaru-2-2-2-5-Engine-Short-Block-Legacy-Outback-Forester-Impreza-/320981186335?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ASubaru&hash=item4abbf8371f&vxp=mtr Anyone dealt with SSI? I don't want to make a prolonged ordeal out of this. Iput this engine in in one day, I'm figuring I can pull it, pull heads, put new HG's and the heads belts, pump, pulleys on the shortblock and have it back in in a weekend.
Nuts. Put an engine with a rebuilt top end, 3 months ago and now it's getting rod knock. Burned a little oil all along too, so I think the shortblock was worn out. I shoulda known. 1999 forester L auto SOHC NA I'm thinking of this shortblock... http://www.ebay.com/itm/06-07-08-09-Subaru-Legacy-Engine-Shortblock-2-5L-4-CYL-Non-Turbo-/221000965791 Since it seems the 1999 was a 253 and the 08 Forester I have is a 253 also. I got the old original 253 in my garage with a rod knock which I could rebuild if I had the time and patience, but I doubt my skills in that area. Bolting on heads and torquing them correctly I think I could handle. I never hear much about building bottom ends here.
Ball joints first. There are tricks to getting the pinch bolt out without snapping it off, which is VERY common, and a pain to work past if you do. I drill the center of the thread end with a 1/8" which seems to allow the the threads to loosen enough. the heat of the drilling may also allow the PBlaster lubricant to penetrate further into the joint.
Wobbly OBW
uniberp replied to jarl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
^this. Or just inspect them for inside/outside wear. -
Overheating
uniberp replied to ktdenali's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I have not seen mention of thermostat. many claim only OEM thermostats are worthwhile. -
My niece smoked the Legato (1997 Legacy Auto wagon, 2.2 4EAT) up near Minneapolis. Good KYB struts, decent tires, new wheel bearings, new front brakes, all timing stuff. Remote starter, aftermarket sunroof, pretty clean overall. I think she ran it out of oil. Inquiries invited for any parts or whole thing.
I just put in a top-end rebuilt, and after switching to Kendall GT1 20-50 because I think some of the standard "piston-slap" noise is rod bearings, I wanted to quiet it down a bit. It worked, but now it smokes a little. I hope it's from being slightly overfilled, about an 1/8" above full mark. Maybe you are overfull?
