mrfeh
Location
Oregon
mrfeh's Achievements
Advanced Member (3/11)
10
Thanks. Below is the reply from Anthony. Can somebody confirm that I need all 4 parts in the links he provides? Anything within 8 inches of the gas cap on my car is a rusted mess and needs to be replaced. ------------------------------------------- We usually will sell the filler pipe, top valve, ring and seal and screws all listed here http://www.subarupartsforyou.com/cp_partlistbymod.php?model=Outback&subcat=Fuel+Pipe&year=1999 also commonly you may need the upper valve which is attached to the old pipe coming out http://www.subarupartsforyou.com/cp_partdetail.php?partid=16370 it is hard to say beyond that without looking or disassembling etc... all is in-stock
Hi folks. Couple weeks ago my CEL became lit (0440 code), so after reading these boards, thought I'd take a look at the fuel filler neck by the right rear wheel. Well, living in Wisconsin, you can imagine what I found - lots of gunk, crud and corrosion. I'm hypothesizing that there is a leak in there somewhere. My question is - can I make this repair myself? I've done simple repairs in the past, but I'm not a mechanic. Thanks!
rapid directional
mrfeh replied to mrfeh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Just thought I'd let folks know what the solution was... I got a replacement bulb and pulled the directional assembly from the car. I could see that the old bulb (which does have 2 filaments) was still good - nothing was burned out. As I was inspecting things, I noticed the light would get bright or dim as I moved the bulb around, so the problem is with the wiring or connector. -
rapid directional
They work, and at the correct rate. Are there two filaments in the front bulbs? The left side is not as bright as the right side... -
It's a manual trans. A couple years ago the clutch was slipping when I was pulling a boat out of a lake; under normal driving conditions it's fine, but I'm having it replaced as long as everything is apart. I've given them the go-ahead to do the work. Hopefully they won't find other damage when they get in there. It was overheating for a brief period of time - I was almost home when it happened. Given the symptoms, it sounds like exhaust gas was being forced into the cooling system at the head gasket.
