Everything posted by unibrook
I went this route also: BR-3 OBDII reader from http://obddiagnostics.com/. But a bit of a pain to use for me, my laptop battery is dead, so I have to hook laptop up to my cig lighter. And the onboard realtime diagnostics don't seem to work right. OTOH, it does tell me what code is being thrown, and it does allow me to clear it. If I were to go out and do it all again, I would get one of those small Harbor Freight code reader/clearers just for ease of use and handling.
I tightened the Pwr Steering/Alternator belt. Took me 30 mins: 1. Remove the belt guards using 10mm and 12mm sockets/wrenches. This will "force" you to loosen the alternator pivot bolt. 2. Press into middle of belt to check how loose it is. Mine had about an inch of movement. Check this belt and the other belt for wear or any condition problem, since you are so close to it. 3. Loosen the lock nut--about half way down the shaft of the slider (adjuster) bolt. 4. Lube up all of the bolts while you are here. 5. Tighten the slider bolt one full turn clockwise, enough to make the belt only move about .25" when you press down on the middle of it. 6. Tighten lock nut. 7. Replace all belt guards. 8. Start car and test drive, do some tight full lock turning to test for squeals.
Hi, Bumping this thread up with a followup question. 2001 forester 92k miles. cold engine squealing belt and lack of pwr steering assist until all warmed up a few minutes later, then all is normal. Fluid level ok. Whereabouts is the power steering belt tension adjustment gizmo located? What procedure do I follow to tighten it a bit? thx.
leaky sunroof
unibrook replied to charm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
gotta say it...this is why I love NOT having a sunroof on my Forester. -
Legz
unibrook replied to SubaruJawn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
There's a hole in my bucket, dear Liza dear Liza... -
Fun and games continue with my inde shop and the rear bearings they put in less than 1 year and less than 5k miles ago. I called them up and asked if they would fix it for free. They said "bring the car in, if the bearing is still under warranty, we will fix it for free." So I take a couple of hours out of my workday to drive it in there, and when I get back to the office they called and said Subaru won't warranty the bearing for more than 6 months. My shop won't give me free labor to put another one in, they said. Soooooo, why couldn't they figure all that out and tell me that over the phone instead of wasting my time like this? The answer is, they could. But once they hassle you enough to drop your car off at the shop, they figure you will just buckle and say, "oh ok, since the car is already there, go ahead and replace the bearing again for $375." I told them not to touch it, I will pick it up and fix it myself. And they will get no more of my business.
Just to echo what TIMINTC said, if your car is reasonably late model (1999 and newer) the rear wiper motor is probably not the culprit...it has a sensor in it to shut off if it feels too much resistance. So the motor rarely burns out. And the gears rarely strip. You will probably find what timintc and I did that the shaft itself is corroded/frozen. Remove the back gate plastic trim panel...some big phil-head screws, bunch of plastic pop out tabs. Take the motor backing plate off being careful not to strip the 6 small phil-head retaining screws...and get ready to catch the white nylon gears that might fall out. BTW, my wiper arm was corrosion welded onto the drive shaft, and I sheared the retaining nut and end of shaft off as I tried to remove it...turns out you don't REALLY need to separate the two pieces anyway. Then spend 30 mins spraying WD40 and or lith grease up and down the wiper shaft from both inside and out and slowly work the wiper arm back and forth and it will free up. I sprayed white lith grease on all of the plastic panel tabs b4 I put it back in place figuring that this wiper motor grease job will prob become a yearly maint chore. timintc, have you tried gooping some silicone onto the ouside of shaft to prevent water from running down it? I might try this.
Hohieu, I dunno if they used ball bearings. I would assume they used new roller bearings...if that is what gets sold as a replacement part. On the other hand, I am sure they went cheapest route possible. Maybe the bearings they got sucked, maybe my spindle has a lip on it. Dunno. So many dunno's when dealing with a shop. sorta why I want to just dig in and do it myself. Even though the hassle factor daunts me.
That was Dec 2007 I had both rear bearings replaced. Now it is Dec 2008 (< 5k miles later) and they are both howling like a banshee again. @#%&%$$^ I think I will take Gary's advice and try to just replace the whole hub assembly myself instead of paying another shop to screw it up for me. Any junkyards for Subies around Boston?
