![](https://www.ultimatesubaru.org/forum/uploads/set_resources_9/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
Tireman28
Everything posted by Tireman28
More gear
Tireman28 replied to Tireman28's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I can only run front wheel drive. Lol fun they said. So a 4.44 trans 5 speed will increase my rpm cause of more gear??? -
More gear
I don’t need a rear diff. I’m only allowed 2 wheel drive. So I need to find a 4.44 transmission? -
what type of wiring harness do i need to get that wrk with this transmission? the cr is an 2003 impreza that had a 2.o turbo stock. i ttok the motor out of a forester. its an ej25 na, sohc. wondering what kind of wiring harness i need to get, or have one made. and if i need one made who can make them. its for a round track asphalt race car.
I called delta cams and they can do a 230’ grind for my camshaft. I have a 2005 2.5 block and ported and polished 2.2 heads. What are yalls thoughts on the possible power output? Or has anyone done this?
- 8 replies
- 26
I have a 1993 ej22 Legacy. I decided to have the heads ported and new valve and heavier valve springs installed to add 30 to 40 horsepower. Keeping the cam the stock one due to legally being able to race in this class. Just wondering if anyone else has done this and what kind of power they improved. And if there any other modification I can do to add horsepower.
I’m new here and I need some guidance on my recent decision to swap my race car motor. I currently have and ej22 sohc with a cable actuated Manual transmission. I want to swap that motor with and 2005 ej25 sohc motorwith a m/t and also with a hydraulic clutch system, which the 2005 m/t has. I’m asking if all I need is a wiring harness for the ej25 M/T, the actual ej25 motor,and a ej25 manual transmission. Is this the correct path or do I need some adjustments.
