BulletRide
Location
Lwr. Sackville
BulletRide's Achievements
Advanced Member (3/11)
10
so i shouldnt do that? i have the hill holder disconnected..i was just using it to show where i was talking about...so i guess its called the clutch fork then... thats the peice that with the clutch out all the way it wobbles around..and when it does it squeaks which is really annoying...is there anyway to get rid of this.... it goes away seriously if you push the clutch in 1 milimeter..
its a 95 legacy l sedan 2.2l 5-speed it has nothing to do with the pedal.. theres a part of the clutch somewhere where the hill holder brake line connects to.. well that peice that is held onto a bolt by 2 nuts moves/wobbles around and squeaks when it does..and the frequency of the squeaks go up as the revs go up.. now when im driving if i put the clutch in even a milimeter the squeak goes away..im assuming because the cable puts tension on that peice to keep it from wobbling.. what im wondering is if i can change the tension of the clutch cable so with the clutch out all the way, it will be like right now me having my foot on the clutch just a little bit.. i hope that makes some more sense i am getting a new clutch right now...but im just owndering if theres a quick fix in the meantime to get rid of the squeak noises
my clutch isnt under any box or anything..its wide in the open.. but its very loose and rattles around and makes a squeaky noise..so im hoping tightening it is gonna stop that.. i did notice nuts over the big bolt were together...but it seemed to me they were springloaded to keep from twisting any way
i doubt that would help... it doesnt come at all, you cant hear it at all unless im at atleast 3000 rpms... and usually only when its accelerating if i let off the gas and cruise it goes away..even if i stay at high rpms (i think it does...i dont usually cruise around at 4000 rpms) i could try and record it.. its a very very high pitched squealing noise...sounds like a mixture of a sports whistle and a tea kettle...allthough i think its even high pitched then that
