3
Everything posted by Qman
I agree with Nick. The hair on my neck stood up and I got goosebumps seeing his name appear on my screen. Wow! I have a disc for you Paul.
There will be a Remembrance. It will be Saturday July 12th between 2 and 7 PM @ Ed and Jeanne's home. You can come at any time between those hours. Share stories with friends and family. Feel free to bring photo's if you have them as well. Come and go as you please. The address is; The Rachner's 715 232nd St SE Bothell, WA 98021 If there are additional details to share I will do so. Ken Please also note, there will be limited parking. If you can carpool or park at the shopping center and walk or drive up with others.
A good thought Paul. Maybe the next time someone sees somebody in need. Or someone asks a question. Or needs a part picked up or dropped off. Or just an opportunity to be a nice person. Seize that moment and think of Ed. He would do it, why can't anyone do it? Make somewhere a nicer place. Ed would approve!
A long time board member, Edrach, Ed Rachner has pass on. His fight against cancer finally came to an end. He left us late Saturday evening. He is survived by his wife, Jeanne and 3 son's, Eric, Paul and James. And also by Paul's two Daughters. Not to mention his extensive family and friends. Any who knew him will vouch for his integrity, willingness to help anyone. And his all around niceness. He touched many of us and will be missed. Qman Ken, (Ed's friend)
I will be happy to address this. Being as I was the first to do the 6 lug conversion. A lot of thought, contemplation, and measuring went into this. I researched wheel offset and widths. I verified lug size and length. I verified compatibility of the lug nut angles as well. If the wholes are drilled straight and true to the correct diameter and the correct wheel stud and nut are used. It is better and stronger than the originals. Monstaru is correct that unless you have extensive vehicle inspect in your providence than you may be over thinking it. But, he only says this because he knows that it was heavily researched before it was first done! Enjoy, Ken
- 19 replies
- 6 lugconversion
- lug
(and 2 more)
Tagged with:
Most likely suspect is the ignition fuse in the fuse block under the dash. Otherwise check the coil for power. Is this an EA81 or EA82 engine? ECU lends to EA82. You probably broke a timing belt. More than likely the drivers side belt. Remove distributor cap and check if distributor is moving! And, for future reference. If this is an EA82 your best to describe it as a 3dr. It will aid in assistance when you have a problem. Otherwise, refer to it as an EA81 Hatch. It just eliminates unnecessary questions.
This was a good day!
Great job Brian! At my rate of repair you may beat me back to the trail...
When you are wheeling on stuff bigger than your vehicle you can bend things. If I remember he was trying to climb over said object and bent the strut tube right above where it had been modified. These rigs were not normal everyday Subarus. Not ever everyday wheelers. Well, except for mine that is. No disrespect intended but if you wheel and have "never" bent a strut rod maybe you aren't doing the same kind of wheeling that the rest of us are. My Hatch was designed to have the strut rod be the fuse. I could change one in under 10 minutes. I knew if there was going to be a problem that is where it would be. Carried a couple of spares. No problems. Everyone does things differently. If you haven't broken/bent those than good for you. Most of us are not so lucky.
Hatch Patrol's XMas Tree Run 2013. 12/07
Qman replied to ezapar's topic in Meet n' Greet. Your USMB Welcome Center
Cool, I'll have the driveline for you -
Yep, cold as a witches... But, as always we will ask folks to bring some wood for the bonfire. We will have propane heaters, camp stoves, propane and water. Bring food and drink of choice. Bring a shovel and provisions for getting unstuck if need be. Tree permits still cost $10 for those so inclined. Our day camp location will depend on number of participants. The snow was much higher last weekend than in years past. There are a few nice spots further up too. -
The bridge collapsed with the car on it. The "truck" hit the bridge not the car. It fell "with" the bridge...
Mike W did this mod 10 yrs ago. It worked with limited success. He did not have a divorced transfer case though.
I drove it Sunday. Drives like no Automatic I have driven before. Snappy and responsive. Not fast by any stretch of the imagination. But, surprisingly quick and quiet. Solid ride, nice tunes, comfortable. I give it two thumbs up!!
I also owned a '83 GL Brat without T-tops with an automotic and all options. Including rear slider, A/C, dual head lights, cloth seats, full carpet, etc. Definitely not a DL at all. Horrible rust or it would still be on the road! I have pics in a box somewhere.
Are you trying to compete?
If you haven't heard from them call them. They may not have your number to call you for the card number...
upgrade1992 Loyale coil to after market performance type?
Qman replied to Bob B's topic in NA Fuel Injection Engine Tech
You can make it peppier. It won't be real fast but funner to drive. Do the basic maintainence. Maybe replace the head gaskets and add a set of cams from Delta Camshaft. Just keep a good cooling system and it will be fine for quite a while. If you want to race then an EJ swap is probably better suited for that. -
EA82 head crack between valves
Qman replied to spayordie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The crack is not a problem unless the material has seperated. In which case the head will need to be repaired or replaced. When repaired properly, the head will last as long as it did originally. Rule of thumb is if you can get a thumbnail inside the crack it is bad! -
Annual Hatch Patrol Xmas Tree Run, Saturday, Dec 8
This event needs no promoting. Bryan, you did a great job as usual! Ken -
Thanks to all who attended. A small turn out this year. But a fun time all the same. The weather turned out in our favor as well. Perfect new snow. I guess at the top where the tracks ended was a good 2'+ Snow was nice to drive on with out much issue. The kids had as much fun as any other year. Good sledding. It took a minute to get the fire going due to "Green" wood from Greenwater. But once it took off it was nice. Thanks to Rob for taking on the meet. Thanks to Eric for leading one of the groups up. Thanks to everyone again for keeping the antics on the snow instead of the paved road. We have a great reputation because of this and people are always glad to see our group!! Ken -
Well done Subaruman5!! -
OK, the forecast is for up to 2' of snow in the next 2 days. Please be prepared for that. It is gonna be a great time. If any one can help out by buying a bundle or two of firewood at any of the local stores on the way up. It would be a great help and keep those at camp warm!! It takes a big load off of one person if a bunch of people bring a little. See ya there!! -
eh hmm, you meant to say our friend Bryan, right... ha ha!
