3
Everything posted by Qman
Actually, not many hatches left in the Hatch Patrol.
Very nice! Looks to be in pretty good shape. Pics are just a litle unclear to determine that though. You gonna bring it by to check it out. I may have a few parts for it as well. Depends on what else it needs. Ken
6 lug conversion drill template ready
Qman replied to SubSandRail's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Welding the back is overkill. All you need is a flat surface to allow the studs to sit flat. Drill your holes and spot face the backside of the holes. It will leave you with the same amount of material as the stock holes have. I never even welded the "old" holes closed. I was going to but haven't gotten to it yet and have not had any issues to date. About a year on them now. -
Just what Northguy said. I used Champion in the far away past. The isolators are/were thinner than most and you could actually crack them just by installing them. I use Autolites in domestics and only NGK's in all imports.
New blue 84 wagon to add to the family!
Qman replied to Ratty2Austin's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You sure like those blue one's don't ya' Austin? -
Timing Belts and their covers...
Qman replied to JParuBob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The disty gear runs off the back of the drivers side cam shaft. It really wouldn't show anything if the belt broke. Once the pulley is off the answer will be found. -
You can actually strip teeth off around the crank. It will appear that the belts are good but it won't actually turn the belts. You say you removed the disty to check the gear. Does the disty turn when you turn over the car? -
Preview pic of EA-82...9 yr old daughter built
Qman replied to brat86's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's cool! -
Well given that hint, it has to be an '84 Brat.
I will assume it's a Subaru. I will also assume it's a wagon. The tough part will be year and body style. If it dk red, I will guess an 85/86 GL wagon.
2005 Calendars for sale, 23 left!
Qman replied to Subafly's topic in Old Gen.: 80's GL/DL/XT/Loyales...
He's a good kid Tim. He'll come through. Try to be patient. -
A clutch kit for sale on Ebay!!! Hurry ends soon
Qman replied to greggbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Other problem would be that the EA81 and EA82 flywheels are cut at different depths. So it can't use the same pressure plate. -
Limited Slip in the front diff?????
No, the diffs are completely different. There is a company that makes front LSD conversions. I don't recall the name right now. -
Air suspension conversion XT coupe (86)
Qman replied to gk1008's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Standard loyale/GL rear coil overs bolt right up. The fronts are a little different. Struts bolt right up you just have to decide what stance you want your XT to have. Available struts include, XT(2wd)(4WD), wagon, coupe, or sedan(2wd)(4WD). The XT's are shorter in comparison to the wagon, coupe and sedan. I would stick with the whole package from one vehicle so the stance will be even. All you have to do to the compressor is unplug it. You can remove all the stuff if you want to take the time to do so but it is not neccessary. -
I did it with the wheel as a pattern and it worked but I definitely like the pattern(template) idea. I think if you have access to machines a steel or aluminum one with steel inserts woulb be better. Reason I say this is the uneven surface on the backside of the hub makes setting up in a press dificult at best. Nice job though. I may have to get with you, I need to do another set. Ken -
Scott has thesolution for the switch. As far as the buzzing when charging. That is typical of a high amperage charge. Best to keep it under 10amps. I usually try to do 2 amp trickle charges, when I remember to charge ahead of time.
Who sold this GL-10 Turbo sedan?
Qman replied to edrach's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Get ahold of me if you want to do it. It wouldn't be the first vehicle that left my driveway without a roof. -
Well, to use the covers have advantages and disadvantages. Advantages; Keeps objects from getting lodged in the belts. Keeps some of the mud out of the tensioner bearings. Disadvantages; Keeps the mud and gunk that does manage to get in there in there. I guess Subiemech said it best, it's a matter of preference. Intake seems to be better at speed or higher RPM's. Neither of which will benefit you in a lifted 'roo in the woods. It will make driving it on the street nicer though.
The stock 3rd eye grill is for a two headlight system. The grill is larger. I used the stock grill and cutout the hole from the original grill. I also used the original timer and switch. Looks almost stock.
flywheels same for ea81 & ea81T
Qman replied to shanonsf's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Should also note, no grinding on the automatic bellhousing. Manual bellhousings require a bit of fit and fair. -
first gen BRAT spotted.....(purchase secured)
Qman replied to s'ko's topic in Old Gen.: 80's GL/DL/XT/Loyales...
'81 GL Brats came with the EA81 and D/R 4sp. -
Steering knuckle and drive axle
Qman replied to Russell's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The tool is called an axle/cv installer. Very useful little tool. -
Cheap Webers and better adapter plates
Qman replied to tdangelo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Interesting. Every Datsun/Nissan I come across has already been relieved of it's carb. Maybe I'll get lucky one day.
