Qman
Moderator
    3
Everything posted by Qman
  1. What a wonderful quote. As you can see I love quotes that stick out or make you think.
  2. Sorry to hear that Amanda. The good thing here is you got to spend some quality time with him.
  3. You still need to get thatodd tire off of the car. It may include buying all new tires to get them the same diameter. Subaru's are real suseptible to drivetrain bind. The tires make as much or more of a difference as driving on pavement.
  4. I would get specifics as to what they replace before committing to it. Does it get new rings, bearings, seals and gaskets? Ask alot of questions to make sure of what you are getting. And why is the turbo motor less than a single port motor?
  5. The '82 had lot's of little qwirks. Not sure why but it sure kept things interesting.
  6. The intermittent wiper relay is also a timer. If the other things don't work to solve your problem try getting a used one from the junkyard and see if it solves the problem.
  7. Let it sit for a while. Then, go try it out again. You may very well have overheated it. I have smoked a couple clutches before. But, I have never had to replace them. Once they cool the tension comes back and works ok. Did you go through any type of water/mud hole?
  8. Your links are working fine for me. The intake looks to be a Toyota or VW 4 cylinder.
  9. I have seen this before. If you get a couple of other member to duplicate you scenerio. Car on jacks front tires off and no E-brake. You will find that they will spin when the car is running. What are the other symptoms that make you believe the trans is going out?
  10. That would have been my reply as well. You are in Wyoming aren't you? Does it ever warm up after Thanksgiving there?
  11. The '82 disty will work if you use the coil and igniter from the '82. The '82 uses an external igniter instead of the internal like the '83 and newer. And I have an '84 GL10 coupe sitting in my driveway.
  12. Cool, how's Mike doing? Keep an eye open for Hatch Patrol meetings and get-togethers. It will let you meet most of the Sube nuts in the Puget Sound. Welcome to the USMB!!
  13. It was sold to the individual who backed into it. I believe it went back to auction and ended up back in Bonney Lake.
  14. That is a nice wagon on either coast. I like the graphics as well. I have never seen that one before. NOTE; Not all Turbotraction badges were gold. Actually, I believe "ALL" the coupes were silver(chrome) I've seen wagons with gold and chrome. I had a perfect gold one that I had put onto my '84 Turbo wagon. I sold it to Turbones wife.
  15. Cool, if Jon sees this can you send me a copy of the list of parts. I may have other needs that I don't realize.
  16. Those wheels can be found on the '85/86 505 Turbo. I had a set that I pulled off of one as they were testing the engine at the junk yard.
  17. This is all I can come up with, 7050001- Qman’s Brat, Unhatched in the background 7050002- Unhatched 7050003- Zapar’s Hatch 7050004- Name? Highly modified lowered 4wd Hatch 7050006- 84Soob’s Brat 7050007- General Disorders ’83 GL10 2wd wagon 7050008- Edrachs Brat 7050009- Todds Haz-mat hatch 7050010- Todds Brat, this has been totaled, and rolled a coupled of times I believe 7050014- Corky(DrRx) GL10 turbo sedan 7050015- Rxsnrg- RX 3dr 7050016- Austins(ratty2Austin) XT4 turbo 7050017- Milesfox Notorious Trashwagon 7050018- Andrew’s(hondasucks) turbo wagon(?) 7050019- Noah88dl Lifted DL wagon 7050020- Flowmaster’s 87 wagon 7050029- Richies Legacy sedan(non-turbo) 7050030- Qman’s ’92 Turbo wagon 7050049- (?) friend of Sean’s from Portland. This has to be one of the cleanest Impreza’s I’ve seen
  18. Good deal/ Glad all went well for the most part. Can't wait to see the pics.
  19. Yes, that is indeed Ed's Brat. Todd's Haz-mat Hatch is in the background.
  20. $13,000+ Yep, that's what he has into it to date. It is a nice set up but... He was a little dissapointed that he didn't win in stock class again. I finally talked to him this year. He isn't a bad guy at all. He is a gear head and has no problem spending a buck to get what he wants. Word out is that he is building an EJ Brat now. I think he is trying to get more HP than I had at the show. <shrug> His Brat should nicely done when it finally has it's coming out party.
