3
Everything posted by Qman
My new 1986 XT won't start, help?
Qman replied to derburger's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If the drivers side belt slipped it would not run at all. Period. It is possible that you have bad gas but not very probable. Go to your local parts house and buy a can of MAF cleaner. CRC makes a good product for that. The code that flashes when you plug in the green connectors is just the 12 code. Simply, it is the code that flashes to tell you that it is communicating and working. Check for carbon build up on the cap and continuity through the plug wires. Have you replaced the plugs yet? -
Take a step back and ease up a bit! BTW, which manual are you quoting from? The distributor will not "jump" timing without other issues. The belt is good, the distributor turns freely, it tries to start but doesn't quite catch. Does it run if you add starting fluid? Bad grounds will cause poor running but should not stop your car. To the OP, have you inspected the temp sensor? That can also cause fuel related starting issues. Did you add new gas after your 200 miles? If not than that is not the issue. Did you ever clean the MAF? If your code check stated that was a problem clear it up first. -
Seriously, stop telling him to remove his distributor. His code 21/22 is where he should have started in the beginning. Clean the MAF. Clean all grounds AND connections. Clear each code as it comes until the codes are clear. Being that the history of this car may not be 100% know. -
Jesse, which way did you guys come out? You should have tagged with us. The snow wasn't as soft when we went through. Still very tough when you got off the trail.
Good idea, but, snatch blocks basically cut your cable length in half. A 2500 only carries about 50 feet of cable. You get the idea.
The actual ratio is 1.5 of vehicle weight. I had a 4500 on mine and used it more to pull others out of trouble. Brought several bigger rigs back onto their wheels from their roofs. Neccessary equipment for the winch, snatch block, gloves, tree-saver strap, clevis' of various sizes and 20' tow straps. A couple lengths of chain are good as well. 8K winch is too big and heavy for most Subarus. Especially if you have it permanently mounted.
With, you are still in right? Call me tomorrow. I found a carb!
Should be 4 or 5 with me. Only one Subaru though.
need date of wcss11 meet
Qman replied to 86subaru's topic in Meet n' Greet. Your USMB Welcome Center
yes, there were a few. One of the best is a Forester. -
Yes, several rivers and streams in the area. We'll just need to keep an eye on the area as it gets closer.
Still working on specifics. We'll announce something soon. -
Someone on here may have a spare to sell for a lot less. It is not what most people call a pcv. Do you have the part numbmer off of yours? There is no way to make the ecu think it is there and working unless it is!
While I have owned two of the most famous lifted Subarus. I miss my Hatch sometimes. I miss my little lifted Brat(4") more than I miss the big lifted Brat(10"). I have seen Subaru's taken as far as they can go. Between Zap and myself we have probably wheeled a Subaru in every possible condition. We have followed Jeeps, Samauris, 'yotas, you name it. Yes, we did it but it was difficult, usually broke stuff and held up the group. When we would go to Evans Creek with a group of Subarus we would be lucky to do 2 trails. Usually stopping to repair broken axles or struts. Waiting for smoked clutches to cool. Now, enter the Toyota. Stock engine, stock transmission, 6" lift already installed, 35" tires and 4.30/1 gear ratio. $1000. Needed a clutch and water pump to be road/trail ready. This goes anywhere I want it to go. I do not worry about breaking things, I did break a "J" arm on the first outing. But that was my fault. Had to learn the truck and haven't had a problem since. Now, when we wheel we see most of the trails. A day of wheeling means we wheeled for the whole day. I have made a couple of upgrades to the truck that makes it even better. A welded rear diff, on-board welder and air system, front ARB will be added soon. The only thing that I may add after that would be a second t-case. I have a flat bed for it already and it should be done. I will wheel the heck out of it until the frame rots. May be the last wheel I buy!
Do you have a confirmed date yet. I am working on my truck and it would be helpful to know!
Sorry, I just hate seeing random rumor and misleading information. The NW wheelers have done huge things with cleaning up Reiter and mapping it out. Just wish people would check their info before posting it to the internet.
No, what I am saying is that outdated information is just that, outdated information.
You did notice that the link you gave is over 3 yrs old, right?
The answer is YES! Lower air pressure will aid in traction. It allows the tire to be more pliable and it will grip better. I can lower the air pressure in my 2wd Suburban and get any where that a 4WD rig can go in the snow. I did this exact thing on Friday when we had compact snow and ice on all of our roads. Worked wonderfully and got me home without issue.I dropped mine in half. I would suggest that you go to 25psi.
I'll be needing a fix. I'll keep an eye on this. Maybe Zap and a friend will go as well. That would be 2 toys and 1 Jeep if there are no objections.
OK, my turn... Most people that tell you to not use a phase2 EJ25 do not even own one. 30hp is more power, period. My old Impreza(1.8) and my new '95 Impreza(2.2) project run the phase2 EJ25. I also used the original vehicles engine harness and components. I also ran a few other things to make it better. Intake, exhaust, lightened flywheel, PP6 piggyback, Delta 1000 grind cams. 160/158 at the wheels seems to be an upgrade to me. No head gasket issues. Still gets 28 mpg on the highway. Each swap is a little different than the next. The year of the donor motor. The year of your project. All must be considered when building a swapped car. MT, sounds like you got the 2000 grind. If you were looking for torque you should have done the 1000 grind. With the DOHC motors we have started doing the cams several different ways. Either with new valves(longer stems)($500) or with welded lobes($600.00) or with the head packages we offer. Shimming can be a problem and that is why we sell them this way now. And as the pricing goes... we do offer "specials" from time to time. There are a few ways to keep costs down. Send us your cams and we do all the work to your cams and that way you do not have a core charge. $200.00 is one fo the cheapest mods you can do to a Subaru engine. Has anyone priced an intake or exhaust system lately. And, cams give more power/dollar than any single mod excpet a turbo upgrade. We have also done sort of a lay-a-way program. Make small payments and when you are paid up we send you out your cams. As far as the swap goes, any improvement is just that... an improvement! The 2.2's are bullet-proof but they are not indestructable! I have seen idler/tensioner pulleys eat themselves. Harmonic balancers seperate and even come off. The MAFs go bad all the time. They even blow HG's from time to time. Everything has an upgrade. EA81 < EJ22 and EJ22 < EJ25 and EJ25 < Turbo swap. Everything is relative. Just remember, no matter what you do... enjoy the ride!
If Jon OK'd it then yes.
Thank you for all the interest and purchases. I hope all are excited and happy with their purchases.
Stupid cost cutting Subaru crap
Qman replied to Phizinza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It is pretty simple really. The original cost of a Subaru in 1984 was about $3500 US i for a base model. What did the Mercedes cost then at least $10,000 US? There in lies the difference. And to answer your original question... 10% saving per car would be $350.00 multiplied by 1 million units(number used for simplicity)... my math tells me that equals $350,000,000. Seems like a no-brainer to me! Fix it right and you would not be having these problems. Be it your fix or the fix of the previous owner(s). Exhaust studs and head bolts usually strip or come out because some no brainer grease monkey over torqued or used air tools to tighten them. That is why torque specs are so important when dealing with aluminum parts. -
It is a lot further than most of you will find comfortable. The carb doesn't buck or anything. It just runs out of fuel. We have documented over 45 degrees, might even have been close to 50.
