dpoppeli
Occupation
engineer
Vehicles
99 forester, 02 outback
dpoppeli's Achievements
Advanced Member (3/11)
10
2002 outback. The driver-side floor mat has never been adequately held in place by the hook and I'm worried about safety since it tends to walk right under the gas and brake pedals. Dealer said that he wasn't aware of any re-design on the part but don't know if I trust him since I know Subaru had an issue with the 2005 hook (bulletin #12-83-04). Anyone else have this issue with an 02?
May be related to the uncomfortable seats. Things seem to be designed for a slightly smaller average person. Perhaps we ought to get use to it though - I can't see the continued use of gas to hall all that extra sheet-metal around. "My only knock on the car is that the clutch and brake pedals seem a little too close to each other (at least compared to my 97 Maxima). Other than that, I really liked the car. "
Warning to all: I recently "inherited" a Ford and the wipers stopped working. After replacing the multifunction switch with no improvement, I took apart the grill cover to see what was wrong and discovered a few *gallons* of nuts and assorted debirs (yuck) packed into the linkage area. This had caused the shaft connection from the motor to strip and so now I'm looking at a new (junkyard) motor assembly even though the old motor works. Darn critters. When I reassemble I'm definitely leaving some mouse/rabbit repellent pellets in there. Since I haven't had the car that long not sure if the critter infestation happened previously or parked in my drive. In any case I'm now encouraging the cat to get outside and do her rounds.. maybe it will help if I feed her less!
Your profile doesn't mention year or make. You have to remove the whole bloody guard to do an oil change on my 99 forester but it's mainly held on by bolts. There are two side connections which seem optional... I use to wire-tie these points and after a while didn't bother since it seemed to stay without them. The '02 outback has a little access port for oil changes which makes life easier - If memory serves there are a couple of plastic fasteners here but I thought they were captive? Anyway, have you tried Autozone/Pep-boys ?
