27
Everything posted by MR_Loyale
85 DL fuel filter clogged
MR_Loyale replied to danboone's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There is usually an arrow on the filter indicating direction of flow. -
Scion going away...
MR_Loyale replied to MR_Loyale's topic in BRZ and its Sister the Scion FRS/Toyota GT86
Well if you were dating before she was your wife and had a choice of her being named Globnik or Sarah, which one would you prefer? -
My recommendation is scrap the Saturn and get another Subaru.
I had the same thing happen to me. Check the fuses first. Do any of the switches operate a window?
( This vehicle equiped for optional ac)
MR_Loyale replied to Downwash77's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Open the hood and look for capped stubs that would be for the evaporater. Then you would most likely need a reciever dryer and compressor along with the hoses to hom it all together. Check to see if there is a condenser in front of the radiator. -
Wont start after jacking drivers rear wheel?
MR_Loyale replied to Norcalbratcap's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Could just be a coincidence that something failed at that time. Correlation does not equal causation. Go back to basics, fuel, spark, air. -
It all depend on what you can afford. The wrx is depreciating but the still holds their value well. Every 16 yr old punk dreams of screaming around in a wrx. Did you buy the wrx as a daily or sporty wekender? If you don't drive it much and it was to be a daily, might be better to sell it and sock away the payments you would have been making. That's what I'd do.
A leather strap as a pull?
The Georgia Consumer Affairs office can be reached at 1800 869 1123. Ask about the law and filing a complaint.
What state ? The legal recourse available will depend upon the consumer laws of the state where the work was performed. I think most states require an estimate before work begins. I believe Washington requires the shop to get permission to continue if the work will exceed a certain percentage of the estimate. Check the Attorney General's website of the state where the work was performed.
Check fuses, loose wiring, relays.
I lost mine and Bosch doesn't give them with new blades. Does anyone know the size or where I can get them?
What somick said. They use closeouts to box box up junk they don't want that isn't even what was advertised.
Subaru Down!; ea82t 88 gl-10
MR_Loyale replied to Brokenneckj's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Good luck. -
ea82 hesitation and sputter
MR_Loyale replied to loyale1993's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I go down a hill then turn up a hill and that is the point where it starts hesitating. I may see if there is debris in the tank. Not sure how to go about it though. -
I have experienced a similar thing but not on regular occasion. The one common thing are cold damp mornings. Only happens about one a month when trying to accelerate at the bottom of my hill. Feather the pedal and it starts running normally. -
need a clutch in Eugene, OR; any recommendations?
MR_Loyale replied to ajp's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If she goes with the brakes on, the brakes should be your first concern. -
Are your battery cables ends shiny new and tightly connected to your battery posts? Or are they groady greenish and loose?
Check to see that you didn't miss a connection. Did you get a new or used pump? As for the spiking, I have gotten that before on accidentally turning key when distributor was disconnected. I don't think your ecu is the problem.
