27
Everything posted by MR_Loyale
Dressed up properly with that new grill too. I like it.
Probably was the crank angle sensor like GLoyale said in post #8. In the optical version a finely slotted disk spins on the distributor shaft with an optical emitter/detector unit hovering over the slotted disc a bit like a brake caliper on a disc brake. This results in a waveform to the ECU that correlates to the crank angle. Not sure if that is the version in your car though, just the one I am most familiar with.
opinions please; intermittent running problem
MR_Loyale replied to l75eya's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The only time I experienced bucking on my Loyale, it was an Oxygen Sensor. But it threw a code. -
Kia Sephia Sporty
MR_Loyale replied to Loyale 2.7 Turbo's topic in Non Soob Cars and Bikes Discussion
I found this about P034: A code P0304 may mean that one or more of the following has happened: Faulty spark plug or wire Faulty coil (pack) Faulty oxygen sensor(s) Faulty fuel injector Burned exhaust valve Faulty catalytic converter(s) Running out of fuel Poor compression Defective computer If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors. http://www.obd-codes.com/p0304 A way to eliminate the injector as the possible cause would be to swap the number 4 with a different one (if it is MPFI). Be sure to get all new seals and O-rings if you take the injectors out. -
My son is growing up a Subaru junkie
MR_Loyale replied to ironworkerboomer's topic in Historic Subaru Forum: 50's thru 70's
It is refreshing to see good parenting making a comeback! -
Where has all the water gone?
MR_Loyale replied to Luvn737s's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yep that hose is a pain in the ***. Thing is they don't seem to leak at idle so if you look while it idles, no leak. Rev the engine and it leaks. -
SPFI EA82 Swap idle misfire
MR_Loyale replied to gdudik's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check out row52.com I am sure there are EA82's at the Portland yard. http://row52.com/Vehicle/Index/JF1AC422XNC206424 -
Swap out Automatic for Five Speed
MR_Loyale replied to mickytrus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Miles Fox made the gold standard video series on how to do this. Give it a watch: -
Teach me about OBD II Scanners before buying one
MR_Loyale replied to Loyale 2.7 Turbo's topic in Shop Talk
I am glad it finally arrived. I sent it out on Dec 23rd. Looking forward to your threads on CANBUS and OBDII troubleshooting adventures. Lots of learning ahead!- 36 replies
- 4
If your distributor is the optical pickup style, you can open it up and clean the wheel and sensor with electronic cleaner. Just remove the screw on the dust plate(Don't disassemble beyond that point to ensure nothing is messed up). I did this last summer to mine when I had the engine out. I don't have any misfires. Of course I cleaned mine up for my trip this past summer. -
Amsoil use in a 1990 Subaru
MR_Loyale replied to Allanlester's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I just think that EA82 engines (non-turbo) are hard to kill. Their performance may degrade, but they still chug along. -
Checking the coil and grounds is a good place to start. -
CV Joints or Suspension? Weird Noise
MR_Loyale replied to epix's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check the motor mounts. -
Heater Fuses Pop Immediately
MR_Loyale replied to rdweninger's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check the connector on the blower motor itself. I had mine turn crispy and wouldn't run the motor and had to be replaced. -
rodent stank removal heater core.
MR_Loyale replied to Rust's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You can also take the blower motor off, spray a bunch up in there and then put the blower motor back and run on high to circulate it through the system. -
Parts car AS IS. Caveat emptor. You told him it was a parts car. You never promised the engine would run. How do you know it wasn't a good engine and HE did something to ruin it? He won't be out too much anyway even if he just scraps it. You shouldn't engage him any more on this because it is leading him to the belief he will get a refund. Just politely state it was an AS IS sale. Wish him luck and bid him adieu. Folks, in the future always mark AS IS on the receipt.
The hill holder cable is right on the same mechanism where the clutch cable attaches to the clutch fork. (You need to remove the spare tire to see it. You can back it out a few turns. See number 9 in the diagram below:
- 17 replies
- 2
Just a correction. A properly adjusted hill holder does not prevent you from rolling backwards down a hill if that is your desire. Simply let up on the clutch and the hill holder (properly adjusted mind you) disengages. The properly adjusted hill holder is activated only when the clutch is depressed and then the brake is pressed and released while still holding down the clutch pedal. Releasing the clutch disengages the properly adjusted hill holder. I find the hill holder useful on a steep Seattle hill when the car behind is 1 inch from the bumper at the stop light.
- 17 replies
- 2
Factory fill oil EA81, EA82
MR_Loyale replied to MilesFox's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What did you have in their before? -
1992 subaru loyale won't run after starting
MR_Loyale replied to TPaul's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's odd. If I disconnect the mass airflow sensor on my Loyale, the car immediately dies. -
Need wiring help for DS window switch
MR_Loyale replied to The-Big-E's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You master switch unit could be going bad too. I did a writeup on fixing this: http://www.ultimatesubaru.org/forum/topic/149642-power-window-master-swich-fix/ -
The Yakima style is what I am after. Do folks usually buy them new, from the J/Y or craigslist? How much should I expect to pay for such a rack?
