27
Everything posted by MR_Loyale
The SSC is designed to be a racing car, not some Sunday driver. The Veryon needs TWO engine blocks essentially with its W16 design. Besides, have you ever looked at a photo of the Veryon? It looks ***, like it is about to give a ** or something. SSC did it with only 8 cylinders and for about half the price of the Veyron. So yeah, I guess if you are a little old lady or a **** that wants to pretend they are mario Andretti, the Veyron is for you. Editted for content acceptable for the forums.
Re-Blacking Wiper Blade Arms
MR_Loyale replied to Subarule's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I took my wiper arms off and used a 79 cent can of krylon flat black from walmart. Yeah I am a cheap bastard , but it still looks great. -
Is 1183 hp enough for you? No tricks, no temporary boost of hp on a dyno. http://www.shelbysupercars.com/news-100907.php .
possible bad alternator - again???
MR_Loyale replied to heartless's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have gone through several alternators on my Loyale (3 in 120K miles). You can take it off and take it to Auto Zone or Schmucks and they should be able to put it on a machine to test it for you. -
Well on my 93 Loyale, I open the glove box all the way. Then back off slightly and squeeze both of the side walls of the door. Now open the glove box all the way and the detentes should clear the catches. Go the the website I showed and look at the photo. Your relay should look like that one.
I'd try changing that relay. It is cheap and that is what the ECU is reporting.
I am going to take a stab here and others can chime in to tell me I am nuts. I think the kickdown code is related to the automatic transmission. It is part of controlling of hydraulic pressure for switching gears when you stomp on the peddle. Now this seems to make sense if you cannot get above a certain speed. Does engine continue to rev high RPM's but you just don't go any faster? It looks like the relay is an inexpensive part that sits behind the glove box that you can replace yourself. Unplug the old, plug in the new. $12.25 http://www.bestsourceautoparts.com/partsCatalog/geturl/quote/year/1990/make/SU/model/LOY-4WD-001/product/P2020-33062/application/000363207/part/Relay
Don't trust the internet!
MR_Loyale replied to bobs97c5's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That is the best advice for sure. I did that when I did my timing belt/clutch/water and oil pump job and pulled the engine. It all started right up when I got it all back together because I wrote down each step as I took something off. It definitely slows you down but makes up for it in the end. -
I have only done it once. I never touched the distributor. I pulled the engine too because it coincided with my need to replace the clutch. Having the engine out made it much easier to work on. I was also very anal about marking and tagging every hose or connector with a number in the order I disconnected them and keeping that in a list so I could just do the reverse when I put the engine back in. I was under pressure because my dad was sure I would screw it up. But it started right up after the first turn of the key.
91 Loyale 48Kmiles and a few ?'s from newbie
MR_Loyale replied to dtrentr's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I bought my Loyale new and after 42K miles the cheap plastic radiator began leaking. When I went to replace it, I aksed the shop if there was a metal version available and they gave me one for aLegacy I think. Anyway, no problems since. I am at 122K miles now. -
Already Made Them Mad
MR_Loyale replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The main reason I bought my Subaru (new) was because it was a great value. I bought it in 94 as a previous year new model (93). I paid $11K for it. Compared to what others have paid for new cars, I thought I got a good deal. The car has always started up and never left me stranded on the road. I do have lots of little annoyances but compared to Chevy, I am doing fine. On brand new Chevy vehicles, my brother father and cousin all got dogs that ended up requiring $4-16k worth of "rework" - on a NEW VEHICLE!! And on my brand new Dodge Ram 1500, it came from the factory with defective steering that took the dealer over a week to fix. Besides, I enjoy the enthusiasm and knowledge of USMB. -
It has been a little over 4K miles since I replaced the timing belt. WHen should I be opening up the access hatches and retensioning it?
I didn't think to take any. Sorry.
Last July I pulled the engine and did the reseal, clutch, new water and oil pumps. Here are the pics I took. Hopefully someone finds them helpful.
I have a good picture of mine, but I am not sure how to get it up here. I don't have a URL, it is just on my PC.
Yet another Sea Foam thread...
MR_Loyale replied to MR_Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ok. After 130 miles driving with 60% can seafoam in oil and 40% in gas tank I noticed zero change in the ticking. However the engine has more pep and doesn't bog down going up hills if I am in the wrong gear. This morning I drained the oil and tried Marvel Mystery Oil with the new oil and filter. I drove 40 miles and the ticking is still there but noticable less metalic pinging if that makes sense at all. This pitch changed from a high pitch to a lower pitch. I finally decided to employ the anti-ticking device that comes with every Subaru. I turned up the radio. -
I will try MMO this weekend. -
My version of the EA82 doesn't have push rods. I did get it up to about 6500 RPM while accelerating on the freeway onramp. It still has the ticking though. -
Well I changed to oil, put in a new filter and new oil along with 60% of the Sea Foam. I drove it 50 miles slow and fast (highway) and the ticking is still there. Any suggestions? -
I am experiencing a ticking in my 93 Loyale. I am at 121K miles and about 4K miles ago I put in a brand new oil pump and mickey mouse seal (along with timing belt and water pump), so I know that can't be the cause. I read some of the other threads here and went and got myself some SeaFoam to try in the oil. I also got a new oil filter just in case there was some sort of issue with the one I have on there now. The oil has been regularly changed, but I haven't ever done any Seafoam or other induction/oil/injection cleaning. I have owned the car since new and I do recall at about 20K miles the dealer offered me a similar "service" for $80 but at the time I thought it was a scam. My intent is to put Seafom in and drive from Bremerton to Portland and back (snag a powerball ticket while I am there). This will probably be around 400 miles and about 6 hours of driving. Is that too long to leave SeaFoam in the oil? I will be changing the oil Sunday.
a sad day 01/03/09....
MR_Loyale replied to ()__1337_CRAYOLA__()>'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am saddened to hear of this. He will be in my prayers. -
So insurance wants to give me...
MR_Loyale replied to Yo'J's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If it is the valve I am thinking of, you can put a resistor in there and fool it. I drove for the longest time with my light on because I refused to pay $120 for a solenoid which is just an electromagnet like your doorbell. I finally found a place online that had it for $48 and I broke down and replaced it.
In my Loyale on the passenger side engine compartment there is mounted a vacuumn tank that is used to operate the levers for the hvac. My heater would not switch from heat to windshield today so I checked it out using the wet finger test. I could feel vacuumn in the hose before the tank and when I connected the tank output hose directly to the tank vacumn input hose, bypassing the tank, the levers worked. Now it generally isn't my experience that smart car makers put in useless pieces and Subaru is a smart car maker....right???. But my hvac levers switch without the tank which leads me to question if it is necessary at all. Does it just even out for variations in vacumn with engine speed? Is something like this available at the average car parts store like Schucks or Auto Zone?
