YOWZA
Location
Colfax, CA
Vehicles
1996 Subaru Legacy
YOWZA's Achievements
Member (2/11)
5
O2 sensors 1996
YOWZA replied to YOWZA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
CowaBUNGa!! Mission accomplished. After working on it for half the day, I became frustrated and reached out for help and sure enough soon afterwards it busted loose. I think i tried all your suggestions and not sure which one worked, but I appreciate your help. thanks -
My 1996 outback barely failed smog so I've decided to change out the sensors, change my oil and plugs and run some “guaranteed to pass smog stuff” I ended up breaking off the rear sensor but its a very clean looking break and can be welded back on the cat. Any ideas on how I can separate the sensor from the cat part? Ive tried heat, ice, wax, pb, etc, etc
Thanks Idosubaru! I ended up taking off the belt and decompressing the tensioner. Put it all back together, pulled the pin, all marks looked good. However, after turning the crank 2-3 times, the 2 marks on the bottom cam drivers side is off by about 2 teeth. Next time I take the belt off should I rotate the bottom cam 180 degrees? Would that make a difference?
Finally back at it! I'm putting the new pulleys on and want to make sure the timing belt tensioner is in the correct position. This tensioner looks different than the ones I've been viewing on line. Looks like most of them are 1 piece. I can't remember what it looked like when I took it off. ( should of taken pix) I guess the tensioner, after the pin is pulled, will hit against the bracket behind the pulley. Does this all sound right?
