3
tylertrend last won the day on July 3 2024
tylertrend had the most liked content!
Gender
Male
Location
Vero Beach, FL
Interests
Flying and Cars
Occupation
Air Traffic Controller
Biography
A long time Subaru enthusiast here to offer my knowledge and parts when needed
Vehicles
N/A
Recent Profile Visitors
3350 profile views
tylertrend's Achievements
Advanced Member (3/11)
41
Just a quick notice to direct your attention to my post under the parts for sale section for anyone needing an EA81 turbo engine or wiring/ accessories. These parts will most likely be gone by the end of this month as I can't keep moving them around the country.
Holy lord, sounds like the excrement has really hit the recirculator at SOA engineering. I never cared for the FB's and how buzzy they sound (or the fact they are under square engines) but our 2.0 went over 130k with no internal issues. I think I'll stick with my SUS and its comparatively minor problems though.
My recently purchased '99 SUS is making some very loud squealing noises from the front left area. It's a rotational noise and changes pitch with vehicle speed but is VERY pronounced at slow speed. Several weeks ago it only really did it when turning but now it's pretty much doing it all the time but worse when turning. Powering hard through low speed turns helps quiet it down but it never goes away entirely. I recently performed a full front brake job with new rotors, pads and calipers on both sides; needed done badly anyways but no change. Everything else in the front end appears pretty tight. The vehicle only has 50k miles and it handles like it. CV's appear fine, struts aren't broken or rubbing on the body. Kinda at a loss right now and I don't have a workspace currently to perform any diagnostics. I've seen other threads that mention the possibility of wheel bearings with this issue but I've never heard a bearing make this sort of noise firsthand. The RIGHT side wheel bearing has a very small amount of play but the LEFT side is completely tight. RIGHT side doesn't seem to make any noise. Any advice is appreciated.
1993 Loyale 3AT - What do I need to know
tylertrend replied to tylertrend's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ah yes I am all too familiar with the EJ25D HG issues. Timing belt was done in the last year along with cam seals so all should be well there. My 99 Outback had a bazillion miles on it and it benefitted from trans-x. -
I appreciate all the great input on this thread. I recently found a '99 SUS in Maroon/Gold that I picked up today. It is overall a very solid car with only 50k miles that I would say is a kinship to my formerly owned '99 Maroon/Gold Outback. -
For sure! He wasn't around to show it this weekend but next week I'm gonna check it out. -
Thanks for the write-up. I had aftermarket axles on a fwd ea81 car and it was obvious they were sub par. If I end up with the vehicle I'll keep those seal kits you have in mind. -
tylertrend started following Over heating and 1993 Loyale 3AT - What do I need to know
Looking at picking up a really mint '93 Loyale sedan 4wd that has a verified 33k miles. Super clean inside and out. This would be my first foray into the EA82 platform and have a few questions maybe the pros could answer. 1) Even with the low mileage, the timing belts are almost 30 years old and have never been changed. How much should they be trusted? 2) 3AT - I'm told it works fine (will verify) but again age vs mileage, should a basic fluid and filter service keep it healthy for years to come? Can't imagine governor gears or oil pump issues, etc popping up at just 33k miles. 3) Anything special to know about the SPFI or OBD system? 4) Any other quirks of this chassis/drivetrain I should be aware of? I know EA82 engines can develop issues with lifters and head cracks but that's about the extent of my knowledge on them. I know the 3ATs run high RPMs but my commute is strictly back roads up to about 45mph so that's not a deterrent to me. Any input would be greatly appreciated.
It looks very good! I believe I sent you some mirrors a couple years ago now that I think of it
This vehicle is now for sale, post in the for sale thread
The heads probably are the same, the block is only different in that the piston design is different from the 251/253. There are pics on google images, they're kinda unique. The manifold is different. I used to own a vehicle with this engine and it always ran smoother than any other SOHC Subaru
- 29 replies
- short block
- single port
(and 3 more)
Tagged with:
What’s this thing?
tylertrend replied to Olyroller83GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Looks like a first gen front lower ball joint
