shadetreemobile
  • Location
    turlock ca.
  • Referral
    google
  • Biography
    lifelong wrench and restorer. looking to restore 1987 rx turbo sedan.
  • Vehicles
    1987 rx
Recent Profile Visitors
566 profile views
shadetreemobile's Achievements
Member
Member (2/11)
  1.  i got some pics up on a newer post. How's the safari going?
    1. kaki
      kaki
      Thanks again mate, hoping that you are feeling better now? Taking  a brief break before heading deep into the Serengeti. If it is still available upon my return,m then we talk more about it.
  2. I should have done that to begin with - too late now.
  3. I already had an spardnubbin change the fitting over to 134a and evac + refill system. It lasted 2 months - then blew the compressor seals. Now i'm trying to change it 100% 134a. If the condenser will take the pressure i'm good to go - as all the other parts are avail. over the counter.
  4. I'm trying to change over my r-12 system to 134a. I can't find a 134a rated condenser. What year did subaru change over to 134a? What models would interchange with my 1.8 turbo? I can get all the other parts over the counter. Also - would it be worth rebuilding my compressor with a 134a rebuild kit?
  5. What is the switch/sensor/meter on top of the thermostat housing on my 1987 rx turbo sedan? It seems to meter crankcase blowby into the intake. What does this do? Control cold idle?
  6. i would'nt know to post a photo on a computer. It's a spider type manifold (i think) and it looks fairly simple to remove.I'm afraid i'll snap off more bolts is the process.
  7. bolt already has a left-handed drill bit broke off in the bolt. I'm thinking of removing the entire intake and taking it to a machine shop. Thank for the comeback.
  8. Need help finding a intake manifold - thermostat housing for my 87 rx turbo. I have a stripped therm housing bolt that nobody can get out. As the therm housing is cast into the intake - i'll need the entire part. Does anyone know what years interchange with this motor (ea82)?
  9. took it to dealer - his computer calls it an RX. i was 1 off on the vin (2 instead of a z in the 12th spot).
  10. I bought a turbo 1987 4-door sedan. Vin jf2ac56b5hgz18182. Is this a rx? a gl? subaru of america says the vin is invalid. Having trouble tracking down parts and service interval info. It has 130000 miles and has no service record. Did it need a 100000 service? any info would be great.
