Wet cat
Everything posted by Wet cat
I already did the timing and all the components amd the water pump. New hoses new radiator and cap and thermostat. Thst was 450 in parts i did most of which people keep saying replace. What my thought is when the water pump went which i saw when i took it out. The paddles were worn. So that was obvious. I think that the heads failed after that because before so i was driving this thing back and forth across the country many many times a year. So the head job for 600 is him not replacing anything i did. He just takes off the heads puts new gaskets on amd puts it back together. While they are off i was gonna have them checked for straightness.
I did the timing belt and components with it. I got a kit from rockauto that had the water pump and pulleys. It was everything. I didnt do the timing belt cover gasket. But i meant to. When i ordered it i accidentally got the front crankshaft seal set. Which i guess will now get used amd ill make sure to actually gwt the timing cover gasket set. The mechanic who quoted me 600 said thats just doing the heads if i bring parts. I guess im gonna get this parts list together.
So i have a 93 legacy non turbo. It was running fine. One day out of no where it got hot. I pulled over waited 6 hrs and got it home. It never got to the point it was blowing smoke and acting crazy. Was just hotter then normal with a little steam. I replaced the thermostat and radiator cap. It still ran hot.i checked the block for combustion leaks and it was good 5 of 6 times.I then did the timing belt water pump and radiator. New hoses and components with the timing. It was good for about 3 days. My lower hose came loose or something and i got hot. I topped everything off. Tightened my hose clamps and it seemed ok. Then one morning not more then 3 days later it lost all the coolant from somewhere. I left it in the parking lot. Came back 2 days later filled it with water and got it 2 miles home. I put in a new radiator and it still runs hot. I pulled the thermostat to check it and its working as it should. Im a bit lost. The fans work when the heater or defrost is on. The lower hose wasnt getting warm at all. The car does have 262k
