4wd93loyale
    2
4wd93loyale last won the day on May 30 2018
4wd93loyale had the most liked content!
  • Location
    Pomona, Ny
  • Occupation
    Drain tech/plumber
  • Referral
    google search
  • Biography
    1st time loyale owner and Subaru owner. need help with this relic.
  • Vehicles
    1993 Subaru Loyale Wagon 4WD
Recent Profile Visitors
860 profile views
4wd93loyale's Achievements
Advanced Member
Advanced Member (3/11)
5
  1. I have a 93 loyale wagon, and recently the ebrake will work for a couple of weeks then not work for a couple of weeks, if I turn the wheels and have someone pull the ebrake I can see it working near the brakes. I’m confused, please help lol
  2. I was under the impression that once they start clicking they are done. Also I think the previous owner might have already replaced the front passenger side one, i have never rebooted an axle I always replaced them on my other cars. Does anybody have a link for the process?
  3. I got a 93 4wd loyale that needs front left axle replaced. New to Subaru’s what’s the best method? Should I change all of them or just that one? Also how to stop cat from burning the boot? Thanks in advance
  4. So I connected those wires under the drivers seat and nothing happened, at least that I noticed. The belt is stuck in the on position so it’s not all that bad, I wonder what those wires are for. There are none under the passenger seat that I can see.....
  5. I will splice them together tomorrow and see if that resolves the problem. Thanks Dave and everyone else, this forum is golden
  6. There is a wire under the driver seat that is cut in have and taped off, perhaps that’s the wire for the seatbelts?
  7. So my seatbelts haven’t moved since I purchased my loyale, it’s a 93 wagon. How can I get them working? They are stuck in the on position
  8. It’s a ‘93 and she’s running real nice, ran a new wire from the link to the fuse box.
  9. What is the best way to do it? Replace that whole harness, or just that one white wire
  10. The new wire goes in after the links, just got back from a 45 min ride no issues no burning smells. I just wont turn the ac on again lol, hopefully she last a while
  11. Can I wire it the way I have it? It works, I have it tied in after the link and before the fuse box. Can that cause any problems if it’s just an old wire issue?
  12. If I connect the new wire to the white wire below the link and than connect all the wires to the fuse box it works. That white wire has to power something else along the way
  13. The white wire did have 12 volts below the link box, it faded the further down the white wire I went with the lowest being right before the spot behind the fuse box
  14. If you also bypassed the white wire and got no results then that also points back to the fusible links as the problem. As Dave suggested, see if you get 12v coming out of the links box at the white wire. That will help nail this problem down.
  15. If it was the fusible link this whole time I would feel pretty damn stupid lol, yeah I already bypassed that white wire with a new wire from the link to the fuse box and it didn’t work so I figured maybe that white wire spits off to something else I couldn’t see and bypassing it caused it not to work. I’m going to take a half day tomorrow and see what I can come up with I’m just happy innow know something... THANK YOU ALL FOR THE INFO YOU GUYS BEEN SHARING, if it wasnt for you guys I deff would have given up already
