88SubGL
    9
Everything posted by 88SubGL
  1. Thanks. I appreciate the response. I’ll take the timing covers off and get a look at the tensioner and water pump.
  2. I bought a 2002 Outback sedan that was JDM 2.0 swapped and I’m trying to figure out what Aisin timing belt kit I need to get for it. So apparently, the intake, as well as the right side cam gear and crank gear were changed to the 2.0 from the original engine. Do I need to worry about the size of the engine or just get what kit is called for for this car?
  3. I bought a 2017 Legacy Sport and the passenger seat upholstery is messed up. I could get it repaired but I found a matching power seat cheap. So the question, is the wiring there to replace my manual seat with the power seat and it work? I know in my older Nissan pickup’s, that the wiring harnesses are all the same, it doesn’t matter what options it came with. You can add options that it didn’t originally come with because the wiring is already there.
  4. Adding a relay to the ignition circuit may help.
  5. Another Subaru that that dealer hasn’t touched, because that dealership seems to be the source of most of the problems. Are the issues all ironed out now?
  6. Because he’s had so many problems with this car and right now it’s running ok and nothing is falling apart at the moment. Time to sell! Haha
  7. They won’t let you see or get in YOUR car? Tell them you need to get something out of the car. If they’re still hesitant, go to the owner of the dealership.
  8. If you don’t feel any play in the hinges, then it’s probably the door adjustment. Long doors can be a pain that way. I did paint and body work for years and when I first started, my uncle who started doing bodywork when they still used lead, taught me how to adjust them. Take a short piece of 2x4 and place it 6-8 inches from the front of the door jam, between the rocker and the door, and kind of push up as close the door against the 2x4. Do it two or three times and check and see if there’s any improvement. Don’t go crazy with the pressure. Used to have to do this on ‘70’s Chevy’s, there hinges were welded to the body, no bolts to play with.
  9. Do you have power to the small wire on the starter? Start there and work your way back. It could be the ignition switch, not the part where key goes in, but the electrical connection.
  10. Awesome job! No wonder your daughter wants to claim it in 6 years.
  11. Nice work! I never thought of New Zealand as being a rust prone area. Shows how much I know.
  12. The machinist that I use, told me that on a Subaru, all you have to do is look at the valves wrong and they bend. At the time he had about 6 sets of Subaru heads sitting there. He also said that the valves are not expensive and he charges $250-$300 to recondition a set of heads.
  13. That engine is so easy to pull, there’s no way I would do it in the car unless I had no other choice. Kudos for getting it done.
  14. I guess it would depend on how solid it is. If it’s rusty, I wouldn’t even consider it.
  15. I don’t know about the XT, but my 6 cylinder 2005 Outback had a 5 speed automatic. I’m pretty sure all n/a 4 cylinder cars had the 4 speeds.
  16. I would say, if you’re wanting to do the EJ swap sooner than expected, go with the nitrous. At least you should have some fun before the swap.
  17. Nice looking DL! Especially with 250k on it.
