88SubGL
    8
Everything posted by 88SubGL
  1. That was a nice car. I hope the insurance paid you well.
  2. If it’s the original alternator, have it tested and if needed have it rebuilt. Better than the aftermarket junk.
  3. There is a small coolant under the intake.
  4. EJ it. Lots of information here about it.
  5. I have an ‘85 Nissan pickup that had 400,000 miles on it before I opened it up after it blew a head gasket. I bought it with 75,000 miles on it and used whatever was the cheapest oil and filter I could find, including Fram filters, and changed the oil every 3,000 miles. I was surprised to find the factory crosshatching in the cylinders. Cleaned up the pistons, re-ringed it, new bearings, timing set and head reworked and it runs as good as when I first bought it. Point being, based on my personal experience, it’s much less about brands than frequency. I also have an ‘04 Frontier with 281,000, an ‘04 Tahoe with 212,000 and a ‘15 Legacy with 148,000. All running strong.
  6. As regards the brake fluid, you may need to check your brake wear. The fluid level goes down as the brakes wear.
  7. I’m glad I’m not the only one who doesn’t think that’s a Justy.
  8. If it’s built right, there’s no reason to baby it. Drive it like you stole it, it’ll help seat the rings.
  9. If it’s something you’re really interested in, ask whether or not it’s been repainted. It’s very difficult for me to tell, but I think it has. No branding on deck lid and I think I see overspray in different places. Pictures are not good enough to see. If it has been, then you really want to look it over closely.
  10. In 1982 the Camaro was available with 4, 6 or 8 cylinders. So probably the 4 cylinder, I don’t remember the displacement, probably 2.5.
  11. Maybe a dumb question, but is the turbo working? Providing boost?
  12. A picture will help us to understand what exactly you’re dealing with. That way you can get the answer you’re looking for.
  13. Have you checked to see if you have spark? If not, I would start there and trace my way back to see where I’m losing power.
  14. From the outside oil. It’s hard tell from the outside when a non contaminated hose is bad. They deteriorate from the inside. If the rest are original, I would seriously consider changing them. They’re 24 years old, if I saw the model of your car right.
  15. If it were me, when you get it home, change all of the coolant hoses, unless you have done that recently. If they’re all basically the same age, you can expect more leaks in the future, especially the oil soaked ones.
  16. It does sound like it’s not getting enough fuel. It could be a restriction in the line but more likely, based on what you’ve replaced so far, it’s the fuel pump giving up.
  17. Amazing way to diagnose the problem.
