Nowah9
Nowah9 last won the day on February 6 2019
Nowah9 had the most liked content!
About Nowah9
- Birthday 08/23/1997
Gender
Male
Location
Washington
Referral
Google
Biography
92' Subaru Loyale, 85' GL-10
Vehicles
1985 GL-10 Turbo & 1992 Loyale
Recent Profile Visitors
Nowah9's Achievements
Advanced Member (3/11)
9
92' Loyale has no power after new timing belts
Nowah9 replied to Nowah9's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had accidentally moved the cam sprocket while putting the belt on so it was off a tooth. Its running great now! Thanks DaveT. -
Okay I'll give it a shoot tomorrow morning and see what happens when I redo the timing on it -
Okay and if it is off a tooth how do I fix this without taking the belts off? This is my first time changing a time belt so I'm still learning all the terms. thanks for your help and patience haha -
I did all this, the video went over it pretty well. Should I just take the belts off and try again more carefully? -
It ran perfect before and still idles perfect. Can you explain what being off a tooth means and how I can fix it? -
Subaru GL-10 Classic Car Licensing
Sweet! I'll eventually lift the GL-10 but for now I want it to look pretty -
Yeah it sounds like WA is pretty relaxed about it compared to other states. I daily drive my Loyale so I'm not worried about taking the GL-10 on random trips. Cool to hear that other people have done this with their subies! -
I just got my 85' GL-10 licensed as a collectors car in WA. Just excited and wanted to share!
I think this is what happened. Going to replace both calipers and all the pads today. Thanks for the suggestions everyone !
No sorry I meant I even with the e brake handle off and down, the brakes were still engaged. I went back today to get the car and it had rolled about 5 feet overnight since I never set the e brake. The pads must have unsezied somehow while sitting overnight. I got it towed anyways but I'm still pretty confused on why it happened.
I'm not sure to be honest...
If this is the case how could get it unstuck? The pads are definitely still pressed against the rotor like the e brake is on, but I've took it off and put the car in natural.
I probably could but I might as well get some use out of my AAA....is there a way to tell if it's a seized caliper vs the parking brake being stuck? Thanks GD
My front right brake pads are locked up on my Loyale and I am unable to leave the parking lot..I tried removing the Caliper by taking the slide pin out but nothing is budging. Anything I should try before calling a tow truck?
