uniberp1
3
uniberp1 last won the day on December 16 2021
uniberp1 had the most liked content!
Location
Walker, MI
Vehicles
99forester 08forester
Recent Profile Visitors
uniberp1's Achievements
Advanced Member (3/11)
17
It only bangs when it's slipping on ice, and there is no ice now. I'm pretty sure it's the clutch basket in the tailshaft. I'v pulled the tranny before to seal the separator plate, so I know it's doable. Yes, the bet on a used transmission is sketchy. A wreck is best, like you said. I think I can go up to 2003 without a TCU change.
I get a pretty loud bang from the center when hard accelerating on ice. I assume the basket in the tailshaft is worn. 4EAT 200k miles. Engine is a 50k rebuild by https://www.ssisubiespecialists.com/. It's been incredibly strong. There are plenty of transmissions at the local pick-apart. I want to pick up the lowest mileage one. I mean. it's pretty much the same job right? The biggest pain as I remember is the preliminary removal of the exhaust and driveshaft, with all those associated corroded parts. I could remove the rear cover on the new just to check. It's almost worth the $150 to try it. (+$30 for diveshaft) https://luckyselfserve.com/inventory/?make=subaru&model=forester&listing_order=year&listing_orderby=ASC
Maybe it's the outside temperature. It was warmer today after a week in the 20s. 2.5 NA 2008 Forester 4EAT 155k. The AT Temp would start flashing and stay flashing until the car was restarted. Then a few days later the AWD light started flashing. No weird shifting, no torque bind, downshifting, upshifting, everything normal. Fluids clean and normal. Air filter clean. Charged the battery, just in case, no difference. The AT light would start flashing 1 block down the road, followed by the AWD light. Checked any grounds I could find. Unplugged and reseated TCM connectors. Disconnected the battery for 1 hour, and reconnected it. Lights gone and stayed off after 50 miles. Stupid lights.
I just wanted to prove I would not be defeated by a rust frozen longbolt. I used a cutoff wheel to slice the bolt between the knuckle and the control arms, and pressed out the bushings with the stub intact, an pressed in new bushings using a bearing press. I bought the whole knuckle/bearing/hub/backerplate from RA . This sat in a corner for months, just annoying me. I tackled it today freehand using a benchtop drillpress and 1/8 and 3/8 bits. I won't do it again. This part of this generation of Subarus stinks.
