uniberp1
3
Everything posted by uniberp1
When it happens, it gets harsher when I touch the brakes, which indicates a wheel bearing. When it resets, no change when braking. Harshness is just in increase in audible throughout the car. Maybe the steering wheel. Here's what I suspect. This car has 16" wide flat-profile tires. (Yokohama Avid Ascend)The additional leverage put on the wheel bearing due to the large effective offset increases the pressure on the bearing and heat distorts it. The 99 has taller narrow 15 tires. I've had 3 wheel bearing replacements in this car. Granted one might have been cheap, but the other 2 were an NTN and the SKF hub kit. 140k miles. Maybe pothole Michigan has something to do with it. Eventually I will get tired of dealing with it, even intermittantly, and replace one of the bearings. I run it on stands and listen to identify the weaker bearing.
2008 Forester NA. Iintermittant wheel or driveline vibration, seems to be up front. I've previously replaced front wheel bearings/seals. Swapped axles around. One new axle at some point. Seems to heat up randomly on highway and start grinding faintly, increasing, until speed changes. It used to alarm me. Now I just slow down and find a speed where the noise remains constant, not getting louder or changing. After stopping it seems to cool down and reset. Every few days it happens. I think I know why it happens on this year and model and not on my 1999 ForesterNA.
It's all in how the car was treated and maintained and you have no way of knowing that. The engines have aluminum blocks and heads, and even though they now have timing chain instead of belts, they still expand and contract with heat, and that can loosen them up. The high-performance ones are like all high performance cars, designed for thrills and who cares if they last. You can't have everything. I like mine because I know them and can maintain and repair them, but it took me 3 engine/tranny installs (and numerous bearing, axle, struts) to learn those lessons.
If the vibration is constant and predictable, it's a tire, wheel, wheel bearing or axle. My favorite source of intermittant vibration is when a caliper drags just enough to heat up the wheel bearing and expands it to the point that it loosens just enough to vibrate. I have to exit the expressway and drive around slowly for a couple minutes until it cools off. Of course now 1 year after I replaced the caliper, with no occurrences since, it's starting to do it again... I think. Then again the left side VVT pressure sensor started leaking oil and threw P0028 codes. That seemed to cause some rough running a couple times.
