robm2
Location
Terrace, BC, Canada
Vehicles
1992 Loyale wagon 5 sp
Recent Profile Visitors
robm2's Achievements
Member (2/11)
7
Coolant Temperature Sensor (CTS) or Idle Air Controller (IAC). LIke DaveT says, check the wiring on the CTS. Same goes for the IAC. Another thing to try: The IAC has a stepper motor that opens and closes to provide the correct idle speed. Shoot it full of carb cleaner, let it soak a bit, and turn the engine on and off a few times to work it.
Is there a relay that switches the high beams on? The relays on these things get old and unreliable.
XT6 won't crank, out of ideas
robm2 replied to linkthehero1234's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If the solenoid is clicking, but the starter won't turn, it may be the contacts inside the starter motor that get made when the solenoid pulls in. They get worn and burnt. Tapping on the starter might help a bit, it kind of stirs up the contact so a new bit comes into play, but it only works a few times. It is probably easier to replace the contacts than it is to find them to purchase.... I did it once on a Loyale, 10 minutes to get the starter out, 10 minute to pull it apart and change the contacts, and 10 minutes more to replace it. -
I replied in another thread: Yes they will fit. From what I can see on the website, they only have one tire this size, the Ecosa, which is just a standard passenger car radial. Run them at 36 psi minimum. If you can find one that is more aggressive, don't worry, it will fit fine too.
165/80R13 were stock on Loyales in Canada. They will fit perfectly, if you can get them. I ran them for years, until they were no longer available, and had to go to 155/80R 13 for snow tires, and 175/70R13 for summers, which reduced the ground clearance, load capacity, and speedometer accuracy.
CTS = Coolant Temperature Sensor. Check the vacuum lines to get the 4WD to engage. Assuming they are the same in 1986 as 1992? I know some cars had manual 4WD engagement, but if it has a switch, chances are it uses vacuum controlled by solenoid valves.
Xt6 gas mileage I don't think it's right.
robm2 replied to xXArchusXx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A comment for Step-a-Toe: 1 US gallon = 3.785 liters I Imperial gallon = 4.546 liters 4 liters to the gallon is sometimes used for quick and dirty calculations, but not when any precision is required. The OP was filling his tank with US gallons of gasoline, so they would be the 3.785 liter version. -
Check engine light help
robm2 replied to DanielsHardLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The unstable idle can be a sticky IAC (Idle Air Control). This is the ECU controlled valve that bypasses air past the throttle to control the idle speed. It is the cylinder in front of the throttle body. If you can get some carb cleaner in there, through the air inlet hose, it might help. -
Vacuum Advance for 1986 BRAT
robm2 replied to Chip Hoppin's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Wasn't there a place in Oregon that used to rebuild them? I found this place in Minnesota: http://advanceddistributors.com/wordpress1/ Good luck. -
[92 Loyale] She was running, now she wont!
robm2 replied to dirtyloyalemobbin's topic in Old Gen.: 80's GL/DL/XT/Loyales...
+1 for the timing belts. Even if they look intact, there may be stripped teeth. -
Funny. All mine had electric fans, and only one had AC, and that was a dealer-installed version. As I recall, the fan rarely ran if the car was moving. Another Canadian market difference, along with the tires.
Loyales all had electric fans. They just bolt to the back of the radiator. A switch in the rad controlled it.
No power does sound like an electrical problem. But the suddenness of the failure would have me checking the timing belts, just in case.
In Canada, all the wagons came with 165SR-13 tires. The modern equivalent is 165/80-13.
