HUAWEI3054
Everything posted by HUAWEI3054
No power to the ignition??
HUAWEI3054 replied to soobie87's topic in Old Gen.: 80's GL/DL/XT/Loyales...
CHECK YOUR FUSIBLE LINK AGAIN WITH THEM WITH A JUMP WIRE OFF THE POSITIVE AND THEN CHECK BOTH SIDES REVERSING THE CONNECTION FROM THE POSITIVE SIDE CHECK THE FAR END TOO SEE IF CARRIES JUICE USING A 12 VOLT TESTER THEN IF IT CHECKS OUT PULL EVERY FUSE AND DO THE SAME THING WITH EACH FUSE SOME TIMES A FUSE WILL BURN NEXT TOO THE END CONNECTOR RARE BUT IT CAN HAPPEN SEE IF EACH FUSE WILL CARRY 12 VOLTS AND LIGHT UP YOUR TEST LIGHT ITS A PROCCESS OF FINDING THE BAD PIECE OF EQUIPMENT..,,// THERE IS ALSO A FUSE IN THE WIRING ON TOP OF THE MOTOR THAT CARRIES JUICE TO THE DISTRIBUTOR IT IS NOT IN THE FUSE BOX IT IS IN THE WIREING ON TOP OF THE MOTOR YOU WILL HAVE TO LOOK AT A WIRING DIGRAGRAM TOO SEE IT, ONE ONE THEM BURNT OUT ON MINE WHEN MY GIRLFRIEND WAS DRIVING 35 MILES AWAY AND I HAD TO DRIVE 70 MILES TO CHECK ON IT AND REPLACE THE FUSE TOO MAKE IT RUN AGAIN I FOUND BUY PROCCESS OF ELIMBINATION AND SEARCHNG IT TOOK A WHILE BUT THERE IT WAS ,,..// -
I FOUND THAT IF YU ARE PUMPING OIL IN ONE CLY GET A SET OF AUTOLITE DOUBLE PLATIUM PLUGS , I HAD A SUBARU WITH 215,000 MILES AND ONE CLY WOULD FOUL A PLUG BUT WITH THE AUTOLITE ONES IT NEVER DID AGAIN ......
ANYONE FOUND A WAY TOO InCREASE HORSE POWER ON A 1980 -- 1984 4CYL SUBARU MOTOR PROPANE KIT MAYBE ?? ?? ??
Broken wheel stud, EA81, What's next?
HUAWEI3054 replied to mkoch's topic in Old Gen.: 80's GL/DL/XT/Loyales...
SPRAY WD-40 ON IT AND WAIT ONE HOUR THEN TAKE I GOOD PUNCH AND HIT IT WITH A LARGE HAMMER THE NEW ONE PUT IN AND TAKE A WHEEL NUT AND TIGHTEN IT DOWN AND IT WILL SINK IN TO THE SPLINES -
I WOULD REPLACE THE FUEL FILTER OR TAKE IT OFF AND SPRAY A WHOLE BUNCH OF CARB CLEANER AND WAIT 5 MINUTES AND THEN SPRAY SOME MORE BACKWARDS AND THEN PUT IT BACK ON THEN THEN SEE WHAT HAPPENS
SINCE YU HAVE THE MOTOR ALL STRIPPED DOWN I.D GO AHEAD AND REBUILD THE WHOLE MOTOR GET AHOLD OF ROCK AUTO PARTS OR GET A KIT REBUILD FROM A REBUILDER SEND THE HEADS OFF AND GET THEM DONE ,, AFTERWARDS YU,LL HAVE A BRAND NEW MOTOR THAT,LL GO ANOTHER 180,000 MILES . MIGHT COST ALITTLE MORE BUT YU,LL KNOW WHAT YU HAVE IN THE MOTOR BRAND NEW BEATS USED OVER I DON,T KNOW WHAT //
Rough idle, & check engine light.
HUAWEI3054 replied to espey_16's topic in Old Gen.: 80's GL/DL/XT/Loyales...
COULD BE THE MAP SENSOR NEEDS CLEANING OR THE OXYGEN SENSOR NEEDS REPLACEING AND SOME TIMES THE TEMP SWITCH QUIT AND THE COMPUTER WON,T WORK RIGHT .. MAP SENSOR CAN BE CLEANED BUT OTHERS NEEDS REPLACED -
FREE Engine and Transmission *Seattle*
HUAWEI3054 replied to ABloch's topic in Historic Subaru Forum: 50's thru 70's
HELLO WHERE IN SEATTLE GIVE A MAP PLEASE PLEASE CALL OR TEXT 541 236 8457 I WILL BE COMING FOR YOUR ENGINE SOON
