GrizzlyFox
4
GrizzlyFox last won the day on December 13 2020
GrizzlyFox had the most liked content!
About GrizzlyFox
- Birthday November 22
Gender
Male
Location
West Michigan
Occupation
Automotive service technician
Referral
I am the desert fox
Biography
Mechanical_misfit before the last forum update. Western Michigan old school Subaru stuff and anything rad.
Vehicles
69 360, 84 dl, 88 gl, 77 dodge m880
Recent Profile Visitors
GrizzlyFox's Achievements
Member (2/11)
13
Jimbo's 1988 GL 4wd. Edelbrock equipped!
GrizzlyFox replied to Mechanical_misfit's topic in Members Rides
Thanks to my pal Michael the grizzly is now sporting all the factory spfi parts. Cold starts are obviously much improved. Performance is better than ever as well. I had to modify the stock intake by rotating it 90 degrees and mounting a cone filter in the factory spare tire location. This was due to my dual battery set up taking up room for the stock air box. I've also removed the carpet and given the floors a good coating of bed liner. I've recently picked up a Meyers brand poly plow blade to replace the heavy steel one. We're now located in Michigan's Keweenaw peninsula, aka big snow country. We will see how the grizzly holds up to the demands. Luckily I have a very short driveway to clear. My snow blower is also tuned up and on stand by. Our first snow was yesterday, but it has since melted. I'm waiting on the welding shop to repair the plow blade for me and I'll post picks or video once she's back in snow pushing service. Cheers! -
Good info Mack! Keep me updated. In trying to find time to get over to the junkyard and grab the proper distributor.
Well, looks like a carb disty is on my list along with the Weber. I will report back with my results.
Any ideas on hooking up a carb disty? I assume it has a completely different type of control module. I couldn't find any relevant data on our shop computer. I would like to swap a carb disty in place of the spfi one if I do continue to keep the carb in place.
The car has seemed happiest at about 12 deg timing. The spfi distributor does not have a vacuum advance. Fuel pressure is regulated to 7psi if I remember correctly. It no longer has the stock pump, but an aftermarket inline unit with an old school adjustable regulator. I think I'm going to check with the junkyard here locally and see what they're gonna charge me for an intake, throttle body, and the other spfi pieces and compare from there. The easier solution will be a carb at this point, I believe the return fuel line is cut off, and I'll probably need a new fuel pump as well.
Just did some digging on our shops Alldata manual, and it does say that the ecm controls timing using signals from both the crank angle sensor in the distributor and the throttle position sensor. It also mentions going into a fail safe mode, which makes sense. I guess that couls mean it won't advance timing under load without an input from the tps. I wonder if the MAF would play a role in timing control as well.
I've wondered about it going into a limp mode, but haven't been able to find any info on that while searching. Also, given that its slowly developed the current carb issues, i figured the disty and ecm were still happy to cooperate. I shouldn't have said that all sensors are missing. , the coolant temp sensor is still there.
Good to hear from someone who has some seat time in a carbed auto car. I've had autos, and carbs, but never a car that was both. It seems that my 3at spfi loyale wagon was a pretty capable highway runner despite the high rpm. It's also an option to find and install all the spfi stuff, but given the age and availability I think the Weber might be more economical and easier to service. I am still using the spfi distributor and computer, just with every other sensor disabled and missing. It was that way when I found it. Fuel pump is wired to a relay and switch. Before the current carb issues, the car had no issues keeping up with traffic. I just would like a little more get up and go.
I've always wanted one too. Very cool little rig.
Hey gang, So as of now, my 88 GL wagon, aka Mountain Grizzly Mk2, is my daily driver. I have owned the for some time now and have been slowly upgrading it to better suit my needs, and as things have worn out I've tried to retrofit and overall improve on it. When I got the car, it had way too much carburetor, a 600cfm 4 barrel. It was originally spfi. I used an ea81 intake and carb that I had kicking around to make it more driveable, then swapped to an ea82 carb and intake in hopes of better performance. Now about a year later, the new old stock carb I used is giving me some trouble, and I think before I bother with a rebuild it may be time to swap to the Weber. My main hold up is wondering if I will see a decent gain in performance. The car being a 3at is hopelessly slow, and I'm wondering if my money is better spent swapping in the 5 speed. I have a source for parts but nothing on hand for the swap. I'm not looking for a hot rod, but just something that will do 65mph without taking forever to get there. As it is now, the car is struggling to maintain speed climbing small hills, and has to be driven at full throttle most of the time to hold a steady 55mph. More info on the car itself. 195/60/15 winter force 2 tires, 6 lug swapped. Engine is originally an spfi ea82, xt6 pistons, full rebuild around 30k miles ago. Delta cams, 2.25 in exhaust from the header back to a turbo muffler. Engine is making a solid 20in vac at idle
Weighing my options for a Weber swap. The ea82 carb seems to be down on power and has decided to no longer want to idle when cold. No obvious vacuum leaks but I haven't had time to look more closely. Also, when was the last time you saw an 88 towing a 68? I had to get rid of our 360 shell because we are planning a long distance move and didn't want to haul it with us. I gave it to my boss who is into micro cars and will do something with it. Still very happy with this car. It does every thing I ask. Commute, plow, tow, and get us out into the woods. -
The 854 tempo springs have no issues holding the weight of the snow plow! Can't wait for more snow to try it out. Not that I really want any more snow. -
Nice looking right, and it sounds like it will be all sorted out when you pick it up.
Car Alarms For Old Subes?
GrizzlyFox replied to Subarule's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Car alarm ? I leave the keys in mine. If any thief can figure out how to start it, they can keep the cold blooded old rust bucket. Seriously though, a hidden starter switch or fuel pump switch is my best recommendation. That and don't leave it locked, or any thing worth stealing in the car. -
Here are some extra pics of the Grizzly this summer. It's been a great little chase car for our camping trips. Until money and opportunity permits, we have to take two vehicles on our trips because they're not enough seatbelts or room in the cab of my old Dodge. I am holding out hope I can find a 70s club or crew cab dodge to haul my camper.
