Greetings all I have a partially stripped out crank shaft, due to the dampener pulley wriggling loose.
The first 10-20mm of threads in this shaft are damaged, however I noticed the bolt grabs well with the pulley not in place.
Its a 2.2L EJ22E engine. I measured the crank shaft threads seems go to 80mm deep, and the stock bolt seems to be M13 X 66mm. Meaning with the pulley it goes in about 50mm.
Without the pulley I can actually tighten the bolt snug.
Does anyone know of a source for a longer bolt like the ones that are commonly available for other engines?
Its odd to have a metric size like M13, not sure the thread pitch does anyone know that?
Something like a M13 X 80-90mm class 12.9 bolt?
Thank you in advance.
