Location
Monongahela
Occupation
Machinist
dale47's Achievements
Member (2/11)
10
I posted a thread about my 96 legacy not starting a couple weeks ago. This morning it was the same thing again.crank..crank..crank. The last time it happened I removed a plug wire from the coil pack and plugged in a sperate test wire to see if I was getting any spark. The car fired right up !!. This morning after not starting for 15 minutes, I popped the hood, disconnected the same plug wire from the coil pack and I'll be damned if it didn't fire right up. I shut the car off..reconnected the wire and it's been running fine all day. Anybody have any idea whats going on here. Its a 2.5.
confused
dale47 replied to dale47's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I think it's FM that I"m pretty sure as to what the hell a Chaff and Flare load is. -
confused
Previous to the car restarting yesterday, I had the battery checked and it's connections. The test results were that the battery was fine and the connections were tight. At times it would fire right up..other times it would just crank..crank..crank. The battery ran dead thru over cranking and draining it. Thats why I am so confused..at times it fires right up..others..crank.crank. And when it does fire up..it runs like a charm. -
confused
Thanks guys....learned what a fob is today !! 1 more question....can this keep a car from starting, acting as a kill switch ? Still trying to figure why the car wouldn't start. -
confused
what does fob stand for ? -
confused
The worst has happened. My wife went out to investigate the clicking noise and promptly fixed it. There is a little @#$%^&*ing plunger up under there somewhere...she pushed it in...no more clicking ! My life is over...bye all -
confused
My car has been sitting in the driveway for about 2 hrs now and the clicking noise is still there. Maybe the thing will blow up.... . It is obviously getting juice from the battery to SOMETHING....BUT WHAT !!!!! :-\ Its almost like a turn signal click...but a slower sequence. -
confused
just the basic keyless entry as far as i know brus. -
Hi folks, I'm having a very confusing problem and am hoping someone here can help. My 96 legacy outback 2.5 has not wanted to start for the last few days and I eventually drained the battery attemting to start it. I put the battery charger on and it started to make this weird clicking noise inside the car. I paid no attention and let it charge. 2 hrs. later I go out and..bang..it fires right up. Now I'm confused as to why it wouldn't start before and even more confused because that damn ticking noise inside the car won't stop !! Whether this is related or not I don't know, but when I turn the car off, it shows both front doors ajar on the dash.
Sensor location
Hi Josh, I went to take another look at the photo's and it seems the site is down ...? lol..is it me or the site? -
Sensor location
Hi Josh...Thank You!!
